T98 4 spd shifter
Old Apr 11, 2005 | 10:13 PM
reamer's Avatar
reamer
Well Madathlon, I'v got a F-5 dump.
A T-98 would be lots better than the un-sync-ed 4 speed in there now.
Old Apr 11, 2005 | 10:14 PM
Madathlon's Avatar
Madathlon
Thanks 57 and 58
Old Apr 11, 2005 | 10:15 PM
Madathlon's Avatar
Madathlon
Yes Id agree with U on that one reamer
Old Apr 12, 2005 | 11:25 AM
FOWL1's Avatar
FOWL1
The shift lever in the T-98 has a screw on cap that attaches it to the top of the transmission plate. It is a right hand thread and you might need apair of channel ocks to loosen it up. There is a spring under the cap. The shift lever should "wiggle" loose after you unscrew the cap. You should be able to take the shift lever out without removing the floor pan. Hope this helps.
Old Apr 12, 2005 | 06:48 PM
Madathlon's Avatar
Madathlon
FOWL1: Mine welded. I just looked about a hour ago.. there real nice tig welds by the look of it, But there welded in my case atlest..
Old Apr 12, 2005 | 09:27 PM
sierraben's Avatar
sierraben
Isn't the T-98 the same as a T-18? I know the shifter on a T-18 pops out by unscrewing the cap on top of the trans and then pulling out the little roll pin.
Old Apr 12, 2005 | 09:35 PM
Gear Up's Avatar
Gear Up
Now Ron, you mean to say you aren't into the finer art of double clutching to get the F-5 down the road. I have fond memories of double clutching my dad's F-5 grain truck. Yes in all seriousness it does get old after a while and that is why I'm putting and AOD in the 50 panel when the time comes.
Gear Up
Old Apr 12, 2005 | 11:55 PM
51ford fan's Avatar
51ford fan
From what I have read, I was under the impression the F5 and F6 had the syncro trans in them ???
Rod
Old Apr 13, 2005 | 05:37 AM
FOWL1's Avatar
FOWL1
That's odd. I have 2 T-98's 0ne for my '55 F-250 and one for my '53 F-250 and they both have a screw cap over the ball of the shifter stick. Is it possible someone maybe stripped the threads on yours or it work itself loose and they welded it?
Old Apr 13, 2005 | 07:42 AM
reamer's Avatar
reamer
Hey there 51fordFan
In the '48, I guess the sync. tranny wasn't "man-enough" at the time. Kinda like that "girly" power steering!
the Sync. tranny was an option back then.
My un-sync tranny likes to shift @ 600 rpm, yet in third, in order to get down to 600 again. I lost most forward momentum, and it dogs out in 4th!
Besides .......too many gear teeth-tips in the well-worn, berings.
Kinda useless to re-ruild the original.
Now if there was a bolt on 5-sp for a 239, F-5!
Reamer
Old Apr 13, 2005 | 05:22 PM
murphy's Avatar
murphy
Does anybody have one for sale ?
Old Apr 13, 2005 | 05:45 PM
Madathlon's Avatar
Madathlon
FOWL1, I dont know.. al I know is it welded on mine.. reamer; Murphy, I will as soon as I get my hands on a T5 or T56
Old Apr 13, 2005 | 05:47 PM
  #28
51ford fan's Avatar
51ford fan
Hey there 51fordFan
Reamer
Reamer, thanks for the reply. I hear ya on the worn out 4 speed trans. I pulled mine out when I first bought the truck to replace the clutch and noticed the input shaft moved up and down at least an 1/8 th of an inch. I wasen't worried just wanted to drive it home. At the time I was thinking of an engine/trans upgrade. But now that I have been driving it to work daily, I having so much fun reliving the old memories that I'm planning to keep it orginal. So now I need to think about some repair parts, or see if any of those syncro units are still around. Any tips on how to identify one without removing the inspection cover.
Old Apr 13, 2005 | 07:33 PM
  #29
Earl's Avatar
Earl
Rod, if you want to scope out repair parts, JobLot Auto (www.joblotauto.com) lists most of the stuff you'd need for either your Warner T-9 or the T-98/98A. I haven't checked the prices for all the stuff, but an input shaft for the T-9 (BB-7017-A) runs $150.
Old Apr 13, 2005 | 09:58 PM
  #30
51ford fan's Avatar
51ford fan
Thanks for the lead Earl
