Tech Guys - ABS Light AFTER Sensor Replacement
Old Apr 11, 2005 | 01:25 PM
ExpyBoy's Avatar
ExpyBoy
Guys,
My ABS light was coming on after pulling my foot off the Pedal at start-up... So the ABS Computer seems to check-out but it would be a Sensor...
I replaced the Rear Diff Sensor and YEP light came right back on... Any other ideas??
Also is it possible to disable the light for a day??? I need to get my VA inspection (not scanning yet in our County) and I'm assuming an ABS light is a Quick Failure
Old Apr 11, 2005 | 01:42 PM
jpranger's Avatar
jpranger
rply
Originally Posted by ExpyBoy
Guys,
If The abs light goes off after abuot 3 or 4 seconds after start up thats norman.. its just the ecm running the abs through a series of self checks ... my question is and i didn't see where you mentioned it.... does it stay on all the time and while driving to .
Old Apr 11, 2005 | 03:14 PM
ExpyBoy's Avatar
ExpyBoy
YUP...
Start the thing with my foot on the brake... It cycles through the self test... As soon as my foot comes off the pedal... Light on and stays on
Old Apr 11, 2005 | 07:52 PM
projectSHO89's Avatar
projectSHO89
You will need an ABS-capable scan tool to pull the code if you have 4WABS.
Sorry..
Steve
Old Apr 14, 2005 | 10:05 AM
jpranger's Avatar
jpranger
brakes
Yep , hes right, its a stored (dtc) hard code .. you will need a scan tool to pull retreive the code .. then you should be able to determine the the problem.
Old Apr 30, 2005 | 11:49 PM
kbsvo2go's Avatar
kbsvo2go
Did you try disconnecting the battery after you replaced the sensor? I replaced the same sensor on my 99 xlt awd and the light would not go off until I reset the code.
Old May 1, 2005 | 09:23 AM
ExpyBoy's Avatar
ExpyBoy
YUP... REset the WORLD... Pulled front Brakes to make sure front sensors were in good shape too...
I ended up Disabling the Light for the Inspection (don't ask... long freaking process - involving Soldering Iron)
zrt600guy
1983 - 2012 Ranger & B-Series
Feb 14, 2012 04:10 PM
gthbryce
May 19, 2009 12:24 PM
davebar
Sep 14, 2007 07:33 AM
cghstrojan08
1997 - 2003 F150
Aug 22, 2007 10:35 PM
RobertGordon
Mar 6, 2004 08:22 PM
