OK......the body piece the radiator sits on and basically holds the front clip together....1/4 panels bolt to it along with the headlights and grill.....where it bolts to the frame has rusted away and needs replaced before the front end falls apart. Is that entire big piece called the Radiator mount?.....1995 F-150 I6 4x4
http://www.auto-bodyparts.com/catalog/FORD/FORD%20PICK%20UP%20(FULL%20SIZE)%20%20(87-98/1995
I just did the install today.......thats one thing i could have lived without doing
the little cradels the rad. sits in on the bottom corners is spot welded on but with a hammer and a chisle you can remove them and put them on the new one. Hope yours goes better than mine did
