302 distributor question.
Old Apr 8, 2005 | 06:34 PM
jasonw302's Avatar
jasonw302
Smile 302 distributor question.
Hi. I am putting a 1984 302 Non-roller block in my 1992 F150 4x4. we used the 1992 fuel inject and heads and putting in a comp cams 31-255-5 SD non-roller cam in it. I need to use the distributor from the 92 roller motor. My question is do i need to change the distributor gears or will the roller dist. gear work with the non roller comp cam. Thanks!!!
Old Apr 8, 2005 | 10:32 PM
loggthered's Avatar
loggthered
Thumbs up dis. gears
no the gears are the same the 221 to 302 have the same dis. roller or non roller
should work fine
Old Apr 8, 2005 | 10:44 PM
jrocco's Avatar
jrocco
The flat tappet gear is cast iron. The gear for the roller cam is steel.
Old Apr 8, 2005 | 11:01 PM
loggthered's Avatar
loggthered
Talking roller flat tappet
yea i know that but the gears are cut the same i know my 302 is a 86 t-bird motor and i use a dis for a 75 f100 with a 302 the 86 is a roller and the 75 is flat tappet but it still works
Old Apr 10, 2005 | 08:14 AM
EPNCSU2006's Avatar
EPNCSU2006
The gears are certainly cut the same, loggthered, but if they aren't the right material, then one of the gears will chew the other one up. I would be safe and swap the gears.
Old Apr 10, 2005 | 06:05 PM
baddad457's Avatar
baddad457
You're 100% correct here. loggthered is mistaken in his assumption that a steel cam gear will work with a cast iron camshaft. The steel gear will wear out the camshaft gear.
Old Apr 12, 2005 | 07:23 PM
jasonw302's Avatar
jasonw302
Thanks Guys!!! After speaking to the comp cams tech he advised me that i would have to change the dist. gear from the steel roller to a cast iron off a non roller. So the answer is Yes you have to change gears. Thanks again. I'm OUT!!!!!
sparky
May 21, 2009 08:33 PM
jeffj2689
Feb 21, 2007 11:32 AM
78ford100
Dec 12, 2005 08:35 PM
