Ok so I picked up some parts for the next evolution of my 53 F100 ..... the parts are an 88 Mustang GT 5.0 with a T5 tranny with a dead engine.
I may or may not use the tranny, autos are way better for cruising .... but I am planning on swapping the fuel injection system on to a carbed '72 302 I just rebuilt and have sitting in the shop....trouble is, being a 72 block, it has a non-roller cam with the 302 firing order..... so I was thinking I could use the cam out of the 5.0 roller block to get the correct firing order to match the Mustangs computer.... hence the question will it work? Or do I have to get a non-roller 351W cam? Thanks.
The 88 mustang EFI system is speed density sequential injection.. a bit of a rare breed for Ford. Because it is sequential and it uses dual O2 sensors things are a bit more complicated for your conversion. I think your best bet is to change the cam and because your '72 block is not setup for the factory roller assembly I suggest you use a flat tappet cam with the HO/351 firing order that is also SD EFI friendly. The Crane 444232 fits the bill and I know it performs well, at least as good as the 5.0HO roller cam.
Thanks for the info.......... after just spending most of today trying to get another 88GT to run properly.....came to me in boxes I think I like my carbs better than the 88's system
On a bright note I still have a nice T5 that may end up behind my 351W in the 53 and some mustang parts I prob won't use to flog for profit
It was just a thought...but the more I thought about it the less I wanted to go from the 351W carb to a 5.0 EFI......I guess I was just trying to pull my truck into the eighties but...... Duraspark and carbs are so easy..........
