Sponsored by: Real Truck
sylvania silver star headlights?
Old Apr 7, 2005 | 09:10 AM
sgthawkusmc's Avatar
sgthawkusmc
I put them on my 04 not long after I got it. Personally, I think they were a waste of $40 for me. They're only slightly brighter than stock in my opinion. The light seems to be a little crisper, but that all I've really noticed.
Old Apr 7, 2005 | 02:39 PM
enduringexplorer's Avatar
enduringexplorer
I had them on my last truck. Won't waste the money. I can't even see bothering with those useless "fog" lights Ford uses. they aren't good for anything unless you aim them up into oncoming traffic. I guess you really need them to be cool, though. Everyone seems to drive around with their "fog" lights on all the time. I took mine off and sold them. My 165 watt KC Dayliters do the trick!! Maybe I should drive around with those on???
Old Apr 7, 2005 | 08:01 PM
Pirate16's Avatar
Pirate16
i got them in both fogs and headlights in my 04 i thought it made a pretty big difference.
Old Apr 7, 2005 | 08:20 PM
sg2005's Avatar
sg2005
Any one know if the bulbs are out for the 05`s yet? Meaning the headlights not fogs.
Thanks
Old Apr 7, 2005 | 09:09 PM
tsc's Avatar
tsc
Here is my honest opinion on them. (ps. I got a wee 150, not a SD). Silverstars are great for rural roads or country driving, they are brighter and "whiter". In the urban areas, where there is a lot of ambient light, don't waste your money. I found that I could see farther down the road and that it projected a wider angle and I was able to see the tree line better. (For you city slickers, when driving down a country road, keep an eye out on the tree line, Bambi likes to make surprise appearances).
Old Apr 7, 2005 | 09:33 PM
RR 11's Avatar
RR 11
Jake00 if you remove the grill the access to the fogs are not hard. On my 03 the oil cooler blocked the right fog light. with the grill in place. I have had them in place for two years and I would replace them with Silverstars if I needed to replace them. I drive 85 miles to work mainly two lane and rual interstate. For my money they are worth it.
Old Apr 7, 2005 | 10:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
SilverStar lights are better.
But to get the full benefit you also have to install a relay and heavier wire to the lights.
The stock 16 guage wire does not get enough amps to the lights.
Also the relay will save your headlight switch from certain death from under sized wiring on a circuit drawing to many amps.
Old Apr 20, 2005 | 04:06 AM
riverratmike's Avatar
riverratmike
thanks for all the info. How much does autozone sell them for? Also was reading something online that the sylvania silver star headlights don't have a filiment?
Old Apr 20, 2005 | 08:22 AM
CmprSpecial's Avatar
CmprSpecial
Originally Posted by jake00
how do you got about switching out the fogs. i cant seem to get behind em
I haven't tried, but I hear if you remove the grill (not hard) you can get to them from the back.
Old Apr 20, 2005 | 08:44 AM
Matt M, PA's Avatar
Matt M, PA
I replaced my foglamp bulbs with 9005s and saw a trendous difference. My '05 Ex has 9008 bulbs which according to Sylvania...WIL NOT be offered in a Silverstar. It has something to do with DOT regulations and coating not being allowed on the new 9008 (or H13) bulb.
I understand that the same brightness (not color) can be obtained with Sylvania's Xtra Vision bulbs as the Silverstars.
For the record, I had Silverstars in my former Bronco and liked them. A friend with a '99 F250 (247,000 miles) likes the Silverstars but seems to replace them alot.
SIlverstars or Xtra Visions are not higher wattage, so you should have no reason to cahnge the wiring. I know some of the knock-off bulbs claim to be higher wattage without drawing more power, but I know from personal experience that this is BS.
Old Apr 21, 2005 | 08:25 AM
Steve_250's Avatar
Steve_250
I'm going to pick up the 9007 bulbs and do them on a relay with beefed-up harness. I'll try to find the fogs too, do they need a heavy harness or are they plug and play? Since I'll have the grill out I might as well put in a Tru-Cool tranny cooler too, and save the old cooler for thr P/S. Ok, off to Wal-Mart for the bulbs....
Steve...
Old Apr 21, 2005 | 08:43 AM
Matt M, PA's Avatar
Matt M, PA
I just posted on this elsewhere.
At least on my '05 Excursion the 9005s went right in and have had no heat issues or the like. I wanted to use the 9005s on my Cobra, but understand that harness will not take the extra power usage. In my Ex I have been very careful to check the wiring and lenses and there is no heat in the harness and the lenses only get warm.
As I wrote above, the Silverstars are brighter but draw no more power. I see no reason in upgrading the harness to use these bulbs.
Old Apr 22, 2005 | 11:32 PM
  #28
skipperw's Avatar
skipperw
To get brighter light you could replace your lenses with these.
http://www.procarparts.com/store-det...=onlinestoreDB
They sell on e-bay for about $100
Old Apr 22, 2005 | 11:34 PM
  #29
skipperw's Avatar
skipperw
Sorry. They wont show them. They are the clear lenses that are on the 2002 trucks and up.
Old Apr 23, 2005 | 02:19 AM
  #30
riverratmike
what is the number for the sylvania silver stars that I will need for my 1999 F-250 SD?? I was thinking 9007 not sure though
jc8825
Aug 8, 2010 07:38 PM
mattpowerstroker
Feb 5, 2010 05:38 PM
topdrive
Dec 7, 2009 03:38 PM
oggjay
Dec 26, 2004 10:31 AM
markmac
1997 - 2003 F150
Jan 13, 2001 08:51 PM
