Sponsored by: Auxito
keyless entry install
Old Apr 5, 2005 | 04:32 PM
paradiddle's Avatar
paradiddle
Ford F-150 Vehicle Security/Keyless Entry
2W7Z-19A361-CA
is this a plug and play easy install??
Old Apr 5, 2005 | 05:09 PM
kaysersuzuki's Avatar
kaysersuzuki
if its the stick on 1 that they have out it is really a simple install,just follow the directions,20 min job and thats including a beer
Old Apr 5, 2005 | 05:45 PM
triton_2002's Avatar
triton_2002
You are adding the keyless entry module to a vehicle that was not originally equiped with it? If so, this is not "plug and play" you'll need a good wiring diagram to find all the wires you need to tap into. If you've never done something like this, I would suggest you take it to an alarm shop (or even the dealer) to get this installed.
Old Apr 5, 2005 | 10:01 PM
rkitterman's Avatar
rkitterman
I didn't see if you were also putting in a remote start capable system or not. If so you also need a bypass module for the system. Try www.bulldogsecurity.com for a good start on the wiring diagram.
Old Apr 6, 2005 | 12:15 AM
hometheaterman's Avatar
hometheaterman
I installed a aftermarket Keyless entry in my Honda and it wasn't all that hard. The Hardest part was mounting the brain somewhere. It was also a little hard to get to the wires to tap into I had to strip them with a knife as I couldn't get wire strippers in the tight space I had to work with under the dash.
Old Apr 6, 2005 | 08:45 AM
BillyBob69's Avatar
BillyBob69
The number that you gave, I am assuming that is the Ford factory part number. If so, then just look under the dash, I beleive on the left side and locate the wiring harness for the locks. There should be a junction point where you unplug the harness, then plug both ends into the module. Program the remotes then done.
If you cannot locate or do not have the correct harness there, then go with an aftermarket system. That will be easier.
Do you already have power locks? If you do then you more than likely have the setup you need. Just need the module and remotes. If not then stick with aftermarket and don't forget the actuators.
Old Apr 6, 2005 | 09:02 AM
kaysersuzuki
i assumed he was refering to the new keyless entry pad that stick to the door
Old Apr 6, 2005 | 09:31 AM
BillyBob69's Avatar
BillyBob69
Ahhhh the coded door panel thingy.... Thats another story....
I haven't that one yet. Sorry
But I would think it would be about the same as the main module...
check inside door for the harness. If its there...easy, if not... PITA
Old Apr 6, 2005 | 03:54 PM
paradiddle's Avatar
paradiddle
http://ford.autowebaccessories.com/s...57dc2059944f19
It was the remote keyless entry - fomoco part. I assumed the harness was all setup for it but I wanted to hear from someone who knew. Yes I do have power locks.
Old Apr 6, 2005 | 08:51 PM
BillyBob69's Avatar
BillyBob69
Check with a dealer to find out where the harness is located. If it is there, you are good to go.
Old Apr 7, 2005 | 01:24 AM
hometheaterman
I was thinking of remote module keyless entry not the number pad thing.
Old Apr 7, 2005 | 08:26 AM
preppypyro's Avatar
preppypyro
Just one beer in 20 mins? haha
Old Apr 7, 2005 | 09:56 AM
kaysersuzuki
that was including install time and the wife bringing it to you
Old Apr 7, 2005 | 02:02 PM
locster31's Avatar
locster31
I just installed this on my 02 Supercrew. If you have power door locks and keyless entry, its just plug and play. The connector is located behind the speaker. Your code for the keypad is located underneath the dash on the drivers side, its the white box. You can also reprogram it with your own personal code.
Curt's05
Apr 1, 2015 11:49 AM
Curt's05
Jun 13, 2014 11:06 AM
medicpg
Jun 28, 2013 05:09 PM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
Motorcraftsman
Jul 19, 2000 04:00 PM
