I feel so dumb asking this.... wheres the feul pump??? I heard noises coming from up in the tank when I turned the ignition.. but is that where the pump is?
There should be 3 fuel pumps. 1 low pressure pump in each tank (total of 2) and a external high pressure pump connected to both tanks mounted on the drivers side frame rail between the tanks and the engine.
