05' explorer shifting problems?
Old Apr 4, 2005 | 06:41 PM
2005F250's Avatar
2005F250
just drove the 05 explorer and noticed that if you r getting on it alittle it has a delay between shifts. from first to second youll feel a delay then it kicks in smoothly and accelerates. has anyone else with an 05 experienced this. its a 2005 xlt 4x4. thanks guys
Old Apr 4, 2005 | 07:07 PM
BOJOFASO's Avatar
BOJOFASO
my 04 does that also. i was wondering if it was a normal thing. mine does it in all shifts except fourth and fifth.
Old Apr 4, 2005 | 08:34 PM
captchad1's Avatar
captchad1
In other posts this has been said as nornal operation for the newer explorers with the 5 speed auto. My 04 does the same thing.
Old Apr 5, 2005 | 04:23 PM
PE II's Avatar
PE II
My wifes '03 V8 4x4 does the same thing. It is only noticeable when you get on the pedal for hard acceleration. I compare it to almost like the shift of a manual tranny. Very different and I was going to have the dealer check it out before 36,000 miles to make sure everything is fine.
Does the tranny ECM reflash that I have read about take out this awkward pause in between gears? Not sure if I quoted that correctly.
Thanks in advance for the feedback.
Mike
Old Apr 5, 2005 | 07:53 PM
serussell's Avatar
serussell
Here is a copy of the post that I put ina couple of months ago for my '04 after I got it back from the dealer for this same problem...
Got it back today and can say that it defiantly has a better feel to the shifts. It does still have a little bit of that "lag" feel in the 1-2 and 2-3 shift (so there may be some truth to the statement above about these transmissions having that "shifting pattern" to them) BUT it is much less pronounced and less duration. For the record - the Taurus they gave me to drive had the same shift feel as my explorer with the new parts does now. So it may not be the smoothest tranny in the world, but I would considerate it more than acceptable now - note that I do not think the Taurus has the same Tranny, I could already see the replies coming - just that another electronic shift tranny felt the same. My 04 ranger with the almost same transmission does have a much "stiffer" feel to it, different program I guess. The part they changed was 4L2Z-7G391-AA Bdy Asy-Trans and 12 quarts of Mercon V. The tech or service manager wrote my long explanation up as "customer states incorrect shift ration between 2nd and 3rd"
<!-- / message -->
Old Apr 5, 2005 | 11:21 PM
Exploder-1998's Avatar
Exploder-1998
I have a 98 sport with the ohc 6 in it. My transmission blew within the first month of owning it, so obviously rock steady tranny's are not fords goal. My tranny has and still does the same thing. If I accelerate hard from a stop, it just doesn't shift. It has gone to 5g's on the tach and nothing, it will shift only when I slightly let off the gas. This doesn't bother me too much because if I feel the need to be driving at 5krpm, well I will drive my stang.
Old Apr 6, 2005 | 03:29 PM
TruckLarry's Avatar
TruckLarry
Wow, we have our own support group
Me too!
New 05 (300 miles) bought 2 weeks ago.
The best way I can explain it is it feels like although it is an automatic, there is actually a little man inside the transmission with a clutch and a gear shifter. It feels just like if _I_ were shifting the truck as a manual.
I've owned 3 Rangers and now 3 Explorers. None of the others did this. Shifting was smooth and with very little of the "manual shift" feel.
-Larry
Old Apr 6, 2005 | 09:01 PM
PE II's Avatar
PE II
Hey TruckLarry - I am glad someone else's assessment is the same as mine. The way it hestitates between gears is like you push the clutch pedal in, move the shifter, and then gas again. Have you taken it back to the dealer? If so, what did they say? I can hear it now, "That is normal".
I know these all electronic solenoid control units shifted funny, but it seems so different under hard acceleration. Normal pedal application and the tranny shifts fine.
Mike
Old Apr 7, 2005 | 10:05 AM
TruckLarry's Avatar
TruckLarry
Not yet.
I always have the oil changed at the first 1000 miles so I was going to bring it up then.
-Larry
Mike
Old Apr 7, 2005 | 12:01 PM
smandzak's Avatar
smandzak
Originally Posted by Exploder-1998
I have a 98 sport with the ohc 6 in it. [....] It has gone to 5g's on the tach and nothing, it will shift only when I slightly let off the gas. This doesn't bother me too much because if I feel the need to be driving at 5krpm, well I will drive my stang.
If you have the SOHC engine, it will hold the shift past 5k because you arent out of the power band yet... Our 99 will shift at like 5900 right before the tach runs out of room, and it pulls all the way there. My dad's company 04 would rev just as high willingly.
Old Apr 10, 2005 | 02:26 PM
Zeke from Cajun Land's Avatar
2005f250
Drop me a email... I'm interested in your sport mirrors you have for sale... zekeeldridge@hotmail.com
Old Apr 14, 2005 | 04:41 PM
Free_Lunch's Avatar
Free_Lunch
04 trans issues
My 04 used to shift the same way - had that lag - but I took it again -due to harsh reverse engagements.
They replaced the electronic solenoid and added the additive again to the trans.
The lag is almost but not quite gone.
This is the 5th time it has been in for a major problem.
In twice for the Trans - I am on my 3d rear axle and the antilock brake systen went out.
Old Apr 14, 2005 | 05:28 PM
2005F250's Avatar
2005F250
thanks guys its my girlfriends car so ill check with the dealer. i have th e05 f 250 PSD and then i jumped in her truck and i was like what the hell, did you get a five speed and they forgot the clutch, lol. but thanks for the replies and ill keep you all posted
Old Apr 14, 2005 | 11:08 PM
Exploder-1998
The sohc engine is designed to be run at over 5k rpm?
Old May 31, 2005 | 09:58 PM
SwtPea72's Avatar
SwtPea72
Unhappy shifting problems...
Ok I have a 2000 explorer and I have been complaining about this (yes for 5 years) and I had the extended warranty too. However ever time I took it in - the diagnosis was "we can not duplicate at this time" or "it is just the nature of the vehicle". Naturally I am out of my extended warranty as well and 74000+ miles and it seems to be getting worse now. So if anyone finds a rememdy to the problem please let me know. My dealer had "rehauled" my trans 2x and stated that Ford wont do anything more for me.
Do I drive it till it dies?
Thanks,
Jenn
