Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Automatic compressor drains?
Old Apr 4, 2005 | 10:42 AM
BigDASH's Avatar
BigDASH
How does it work?
I have a 32 gallon tank vertical Husky Home Depot special. I would like to get the most out of it if possible. The drain is on the bottom of the tank.
How would I hook up an automatic one?
Thanks in Advacne,
DASH
Old Apr 4, 2005 | 09:45 PM
beeboy's Avatar
beeboy
it replaces the valve at the bottom of your tank, and plumbs into the sutff up top. Every time your compressor cycles, it pops open the drain valve for a brief moment allowing the water to squirt out.
Here is a good article on it
http://www.paragoncode.com/shop/compressor/
Old Apr 5, 2005 | 12:21 PM
BigDASH's Avatar
BigDASH
thank you Sir
Old Apr 5, 2005 | 08:24 PM
sdetweil's Avatar
sdetweil
I put one of those on my Husky/CH 7hp, 60 gal commpressor, and it flaps open on every stroke from the compressor until the pressure gets up to 50psi.. it doubles the startup time.
I removed it..
haven't been back to look for an alternative
Sam
Old Apr 5, 2005 | 09:11 PM
Howdy's Avatar
Howdy
I haven't had a problem with mine yet. When I first put it on I noticed the diaphram chamber part was hand tight, so I tightened it, (after pulling everything apart to see how it worked..) I kind of questioned some of the rubber seals in the thing, but I'll see how it holds up. Hard to beat for $7 on sale.
Old Apr 5, 2005 | 09:41 PM
rellik74's Avatar
rellik74
You can get a timer type at WW Graingers that you plug into the wall and it opens on a set amout of time. I think it was about 30 bucks. The only problem it will drain the air if the power goes out
Old Apr 6, 2005 | 12:57 AM
Torque1st's Avatar
Torque1st
Posting Legend
I removed it..
Sam
Sounds like you had it installed improperly or it is defective??? Can you check over the instructions again? They normally just open up once per cycle.
Old Apr 6, 2005 | 06:23 AM
sdetweil's Avatar
sdetweil
Well, there aren't many install options. I did just like the link showed, cut the line from the compressor output/tank input to the control switch. This is the unloader line.
inserted a T, and ran the line from the drain value to the T.
I hadn't considered that the valve might be defective tho.
Sam
Old Apr 6, 2005 | 08:32 AM
Howdy's Avatar
Howdy
Try pulling the valve apart. There's a rubber disk in there that's used as a diaphram. It could be that it's not seated right. That diaphram pushes a pin that opens the valve. If it's loose, that might be whats causing it to be too sensitive. The thing isn't a diaphram like in an accelerater pump, it's just a rubber disk.
I know mine wasn't "ready to go," out of the box. I sealed and tightened all the threaded parts. I had it totally broke down - quick and easy job.
The instructions are almost useless, except for the exploded diagram. Better than nothing, but just barely. The link posted is a good one. The only changes I would make is toss the 100 psi tubing that comes with it and go with copper right from the start. If you have buy fittings to T into a metal line anyway, the 1/4" copper tubing will be right there and it'll save a trip, (don't forget the connector for the valve side.) It routes a lot better than the floppy tubing, too. Especially on vertical tanks.
DougJ_1997PSD
Jun 11, 2014 05:56 PM
DougJ_1997PSD
Jun 11, 2014 05:31 PM
da-bees
Nov 28, 2011 07:25 PM
jtybt
Jan 23, 2011 06:40 AM
steuben
Nov 8, 2008 01:20 AM
