Rear Diff Gasket
Old Jan 26, 2001 | 09:30 AM
jamesd's Avatar
jamesd
Rear Diff Gasket
On a 95 4x4,F150,5.8,3.55 rear. Does the pumpkin have a gasket on it or do they just use silicone? I need to change out the fluid. If it doesn't, can someone suggest what year and other model vehicle's I can use?
Jim
Old Jan 26, 2001 | 10:14 AM
pickupman's Avatar
pickupman
Rear Diff Gasket
They dont use a gasket, just silicone.
Old Jan 26, 2001 | 10:38 AM
deadeye's Avatar
deadeye
Rear Diff Gasket
Jim....You may want to refill it with synthetic gear lub.
Old Jan 26, 2001 | 10:40 AM
cgl's Avatar
cgl
Rear Diff Gasket
The 8.8" should have a gasket. My 90 does, and so did another 94. I believe it cost around $4 at the local parts store and I always use the Black ATF that's designed for Oil Pan Gaskets, on both sides of the gasket when I replace it.
Old Jan 26, 2001 | 11:06 AM
jamesd's Avatar
jamesd
Rear Diff Gasket
I do plan on using synthetic gear lube for the rear, from what I"ve read I should use 75W-140, correct?. As well as the Ford Friction modifier. I only have 56k on the truck and it runs great, I'm trying to keep it that way. I'm doing the full tune up on it, plugs, cap, button, filters (gas,air,oil). Tranny just got rebuilt so I hope it's good for a while. Belt and whatever else I can think of.
Jim
Old Jan 26, 2001 | 12:22 PM
PAUL_2's Avatar
PAUL_2
Rear Diff Gasket
Old Jan 26, 2001 | 12:45 PM
cgl's Avatar
cgl
Rear Diff Gasket
Don't forget to grease the front ball joints and you're u-joints.
Old Jan 26, 2001 | 05:23 PM
believer45's Avatar
believer45
Rear Diff Gasket
[font size="1" color="#FF0000"]LAST EDITED ON 26-Jan-01 AT 06:45 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 26-Jan-01 AT 06:43 PM (EST)[/font]
Jim, I have 95 power stroke F250 and have the Ford manual. I looked up your truck and, according to the manual, it does not have a gasket. They say to use a contiouous bead of Ford silicone D6AZ-19562-AA or D6AZ-19562-BA or equivalent applied to the cover. Be sure both mating surfaces are clean and the bead goes to the inside of the bolt holes. Install the cover within 15 minutes of applying the silicone. Torque mounting bolts in a criss-cross pattern to 28-38 ft/lbs. Wait one hour before filling diff.
Hope this helps -- Dave (certified redneck and proud of it)
You might be a redneck if ---------- your best car is a truck.
'95 Power Stroke F250 extended cab long bed, 5 spd, 3.55 rears, ported snorkle, 10Kohm resistor, Delo 400, 147,000 and still going strong. dpharis@eos.net
Old Feb 1, 2001 | 12:31 PM
jamesd's Avatar
jamesd
Rear Diff Gasket
I looked up what Diff lube the manual says to use (80w-90)but I've read people are putting 75w-140. What's best?
Jim
Old Feb 1, 2001 | 01:28 PM
cgl's Avatar
cgl
Rear Diff Gasket
Depends on your climate.
Nitro901
Jan 6, 2017 11:35 AM
mike L
13
Oct 25, 2015 01:32 AM
goosehunta
Dec 30, 2013 08:24 AM
ford-man
16
Nov 14, 2007 09:23 PM
bayou sport
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 7, 2005 12:07 AM
