changing belts on a 292
Old Apr 1, 2005 | 09:35 PM
magicbus's Avatar
magicbus
My roommate is out there undoing the motor mounts on his 292 because the front bolt is blocking him from putting on a new belt. Is there an easier way?
Old Apr 2, 2005 | 01:16 AM
46yblock's Avatar
46yblock
I think the best advise is to tell your roomate to stop, take a breather, ask some questions, and then proceed. The only thing you need to do to change most Y belts is to relax tension on the generator/alternator.
Old Apr 2, 2005 | 01:23 AM
EDMCCLOUGHLOCH's Avatar
EDMCCLOUGHLOCH
Hey, this is the roommate. Firstly, I did get the belt installed. I could not do it by just loosening the generator, though...the problem was that I could not get the belt past the bolt on the front motor mount...it was literally right next to the balancer. What I ended up doing was taking out the four bolts mounting the mount to the block and loosening the one to the frame, and jacking up the front of the engine.
Old Apr 2, 2005 | 01:43 AM
46yblock's Avatar
46yblock
Wow that is weird. I dont have a response, except glad you have it done.
Old Apr 2, 2005 | 01:47 AM
EDMCCLOUGHLOCH
yeah me too. this truck is being very poor. tommorrow I will begin again trying to put on the flywheel. For some reason I think this truck was meant to be non-operable.
Tedster9
Jan 8, 2015 01:28 PM
64F-100
Apr 2, 2009 09:24 AM
Jan 13, 2003 12:23 PM
Kenny
May 10, 2002 06:56 AM
Wizeguy
May 10, 2001 10:08 PM
