Fuel Heater
Old Apr 1, 2005 | 04:02 PM
smashing4455's Avatar
smashing4455
Fuel Heater
How can you test the fuel heater?
Old Apr 1, 2005 | 08:14 PM
PLC7.3's Avatar
PLC7.3
The fuel heater activates below 32*F so you will need to come way north or put your truck in the freezer.
Old Apr 1, 2005 | 11:46 PM
Spectramac's Avatar
Spectramac
I would unplug it if I were you. They have a habit of shorting out and burning your engine harness plug. If we don't need them up here, you can do without them down there.
Old Apr 4, 2005 | 09:33 AM
jonjayjabroni's Avatar
jonjayjabroni
where is the plug for the fuel heater?
Old Apr 4, 2005 | 11:33 AM
redneckmechnic's Avatar
redneckmechnic
near the injection pump just follow the wire coming from the fuel heater its only about 8 inches long before the plug.
Old Apr 7, 2005 | 05:39 PM
smashing4455
Just an update on my location: I have moved to Worcester,Mass and I am still using the glow plugs, its damn cold up here! I thought that my engine has seen it's last days and even went out and bought a truck. After thinking about some of the posts on the web site and not being able to stand the failure of by baby I realized that I probably mis-diognosised her failure. Indeed after looking through old posts on hard starting and white smoke I found that I was indeed mistaken. I just want to troubleshoot all possible aspects of this problem and upon reading I found that it could also be compounded by fuel line problems, hence the question of how to check the heater.
Old Apr 10, 2005 | 01:47 PM
jonjayjabroni
well i live in florida so i'm going to disconnect mine but which plug is it...there is one that plugs on top of it and one on the side...which one is it?
Old Apr 10, 2005 | 06:53 PM
PLC7.3's Avatar
PLC7.3
Smashing the only way I know would be to cool the fiter head to below 32*f and put a test light to see if it works........??
jonjay
The heater is the black square connector on the top of the filter header.
Visit ......... http://www.intellidog.com/dieselmann/idi2.htm for some really good info.
Old Apr 11, 2005 | 07:55 AM
smashing4455
thank you .will give it a try!
Old Apr 11, 2005 | 11:25 AM
fonefiddy's Avatar
fonefiddy
OR test it for continuity. If it's good it'll show some resistance, if not it'll show open
beersy50
Jan 15, 2014 09:18 PM
jakpine
15
Dec 18, 2009 08:40 PM
jpd78
6.4L Power Stroke Diesel
16
Jan 18, 2009 04:28 PM
TransplantX
18
Sep 9, 2008 10:57 AM
