which trans fluid to use?
Old May 21, 2005 | 06:33 AM
Bob Ayers's Avatar
Bob Ayers
Originally Posted by scottcs31
Two years ago I bought a used 2002 F-350 SRW 7.3 diesel with 36K miles on it. Shortly there after I took it on vacation with the standard lube that was in it...(tranny & engine). I averaged 17.8 MPG on the trip. When I returned, I changed all of the fluids with Amsoil products....Amsoil ATF, Series 3000 Diesel Oil, and Sythetic diff/gear oil. 25K miles later on the next trip I took, I averaged 19.6 MPG.....same trip, same route, same load. I was pleasantly surprised to say the least! Hope this helps.
It will actually "hurt" if you use Amsoil ATF in a Mervon V application.....
Old May 21, 2005 | 07:13 PM
2000Expy's Avatar
2000Expy
Question
Bob, I want to SEE your proof.
Old May 21, 2005 | 07:39 PM
Bob Ayers's Avatar
Bob Ayers
Read this TSB on using Mercon/Mercon V multi-use ATFs:
http://www.v8sho.com/SHO/TSB01157ATFUsageChart.htm
Old May 21, 2005 | 08:12 PM
2000Expy's Avatar
2000Expy
Wink
Yes, so? This TSB doesn't show any proof that Amsoil will ruin your transmission.
TSB 01-15-7
Using the incorrect fluid may cause transmission or transaxle concerns.
I wonder what concerns are?
Amsoil Online Application Guide:
2000 FORD TRUCKS EXPEDITION 4.6L 8-cyl VIN Code 6
Automatic Transmission,W/ 4R70W.....MA5[2]
Synthetic Automatic Transmission Fluid
Automatic Transmission,EX 4R70W.....MA
2. Use Mercon V, part no. XT-5-QM. Do not use regular Mercon.
Ford Motor Co. recommends the use of Mercon V in AODE/
4R70W TRANSs which experience vibration & shudder
under light to moderate acceleration above 35 mph or
TRANS fluid brakedown.When changing to Mercon V
drain all TRANS fluid including torque converter
Cooler & cooler lines.
Old May 21, 2005 | 08:22 PM
Bob Ayers's Avatar
Bob Ayers
The friction modifiers are different between Mercon, and Mercon V, so there is NO multi-purpose (Mercon/Mercon V) ATF that can meet both specs.
Be very careful on believing what Amsoil claims!!!!
But, since this is a free country, you are free to use anything you wish!!!
Old May 21, 2005 | 08:29 PM
2000Expy's Avatar
2000Expy
Thumbs up
Anyone can read this FAQ on the Amsoil website. http://www.amsoil.com/faqs/faq4.aspx
Old May 21, 2005 | 08:49 PM
Bob Ayers's Avatar
Bob Ayers
Just ask yourself is the Amsoil ATF worth the higher cost, and the risk of your warranty being void?
As an example of how Amsoil "lies" concerning API certification, here are the
ONLY Amsoil oils that are API certified:
http://eolcs.api.org/DisplayLicenseI...LicenseNo=0995
Like I said, you are free to use whatever you like!!
B.T.W. , are you an Amsoil dealer, or preferred customer??????
Old May 21, 2005 | 08:59 PM
2000Expy's Avatar
2000Expy
Question
Should I be a dealer? Tell me how using Amsoil will void my warranty, please. Could you show me where Amsoil is lying about API certification? I went to the API site. Can you tell me why Amsoil has only obtained API licenses for those oils listed? BTW, I'm well aware that I'm free to use whatever I like, but that is beside the point. This is a discussion about what kind of oils can be used. Originally it was about tranny oil, but now it appears to have move into all oils. Thanks.
Old May 22, 2005 | 11:36 AM
tonum24's Avatar
tonum24
You can use Amsoil and Red line ATF's which are better than Ford specs-and it's that simple! Bob once thought I was a Red Line dealer also, just because I recommend it.
Old May 22, 2005 | 11:58 AM
Bob Ayers's Avatar
Bob Ayers
No, I don't think so, Red Line isn't a MLM company like Amsoil, and doesn't brainwash people....
Interesting comment, do you have any data (other than from Red Line or Amsoil) that says they are better than Ford specs????
Old May 23, 2005 | 08:36 PM
2000Expy's Avatar
2000Expy
Do you have any data to disprove that they are better? So Amsoil is an MLM company, so what? They admit it, you must really have gotten screwed by Amsoil or something.
86f250xl
Large Truck
Jul 7, 2015 05:33 PM
1975-F6004x4Dump
Large Truck
Feb 7, 2014 09:41 PM
propellerhead
Computer Chips & Tuners
Sep 26, 2005 10:25 AM
KevinW
Feb 16, 2004 06:29 PM
kev100
Mar 4, 2003 03:21 PM
