How To Install Intake?
Old Apr 9, 2005 | 12:19 PM
Bolivianfuego's Avatar
Bolivianfuego
I just bought a generic intake for my Expedition 4.6 and I dont know where to start. Is there some generic Write up which can help me follow through with this? Thanks
Old Apr 9, 2005 | 01:05 PM
78Explorer's Avatar
78Explorer
What kind of "intake" are you talking about??? Maybe, a cold-air intake with tubes and conical filter?
Scott
Old Apr 10, 2005 | 05:24 PM
Bolivianfuego
Generic Short Ram basically, Im just looking for some pics on how to take apart the stock intake and what size ratchets it will take and what not.
Heres a photo of it.
http://www.x3racing.com/intake_ram/IN-TK-F04.jpg
Old Apr 22, 2005 | 05:37 PM
Bolivianfuego
Hey guys anymore help on how to install this filter on a stick? Thanks again
Old Apr 22, 2005 | 06:36 PM
supersonicss's Avatar
supersonicss
Is there even a place to install your MAF on that thing? I just installed my AEM Brute force this evening and I love it. I think its worth every bit of 250.00 that I paid.
Old Apr 23, 2005 | 11:59 AM
Bolivianfuego
Do you have directions of the AEM One you can scan up for me?
Old Apr 23, 2005 | 04:16 PM
supersonicss
HMMMM.... I will see what I can come up with.
Old Apr 23, 2005 | 05:48 PM
supersonicss
Taking off the old intake is pretty simple. You need a 10 MM socket and an 8 MM socket. You will also need a flat head screwdriver.
Old Apr 23, 2005 | 06:13 PM
I6power's Avatar
I6power
make sure you tighten everything down real good. One of my friends installed a similar intake on his mustang and one time it came apart! He said he thought his transmission broke cause it was driving really bad and shifting horribly. When he popped the hood he could see that the MAF wasnt connected
Old Apr 23, 2005 | 08:28 PM
2Fords1Jeep's Avatar
2Fords1Jeep
Good question, where's the MAF sensor go?
Old Apr 24, 2005 | 07:08 AM
BigMan69's Avatar
BigMan69
If I may, I would like to put my 2 cents in. I had a set-up just like this but with a genuine K&N filter. If you do a search in here, it seems that even the K&N lets more dirt through. This was discovered when the oil was sent out to a lab. If it is a K&N knock-off, I would have to guess that the problem is worse.
Secondly, now with this set-up, you are sucking air that was heated from the hot engine compartment. The stock, while it is restrictive, pulls cool air from the fenderwell. Seems like the best solution is a Volant cold air intake. It works on the same principle as stock but much less restrictive.
Again, I had the same set-up as you but with the K&N and there was really no performance gain that I could sense. And when I heard about the silica in the oil wearing away the rings, pistons, etc... I removed it. After all that said, if anyone wants to buy one, let me know.
BigMan69
Old May 24, 2005 | 01:33 AM
cipote10's Avatar
cipote10
That happened to me...
I cant' believe this...I bought the same exact intake in that photo and, just like you, I couldn't intstall it on my 2001 XLT. I took apart the factory intake and started to install the custom one but the pieces they give you just don't match - i thought long and hard about and came to the conclusion that they either give you too many or two few pieces...it's hard to tell, since no set of instructions was included.... The closest set up I could come up with was to use just one of those rubber tubes, but then again I changed my mind because there was no support for the rest of the intake and also, I didn't know where to connect the air sensor...if any one out there can follow up on this question, it would be greatly appreciated....
Old May 24, 2005 | 06:41 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome cipote10,to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
