Gear Ratio Question
Old Apr 1, 2005 | 03:17 PM
southernspectre's Avatar
southernspectre
Gear Ratio Question
hey how do I tell what gear ratio I have? I am plannin a 4 wheel drive swap and I was wonderin how to tell what gear ratio is there so I coul dmatch em up.
Old Apr 1, 2005 | 05:16 PM
frederic's Avatar
frederic
By the tags on the door jamb, the tag on the axle, and if neither exist at this point you can lift the truck, disconnect the driveshaft, and rotate the wheels and count the number of driveshaft yoke revolutions, then create a mathematical fraction and compute.
3:1 rear axle ratio means the driveshaft rotates 3 times for every wheel revolution, for example.
Old Apr 1, 2005 | 08:12 PM
southernspectre
thanks alot man. If it comes to that last one....well I just hope it dont come to that last one haha.
Old Apr 1, 2005 | 09:19 PM
frederic's Avatar
frederic
The last one is more work for sure. But in reality, not that bad. Just put the rear of the truck on jackstands, undo the one u-joint, and rotate. Probably take you as long to get the truck up in the air and steady as to undo one u-joint.
Old Apr 2, 2005 | 02:34 PM
Txquadhunter24's Avatar
Txquadhunter24
Counting turns is alot harder then it sounds.
Southern also did you get my reply to the PM you sent me over my 78 F150? I noticed you are a new member an d can only get PM's and email from FTE after 15 post i believe it is.
Old Apr 4, 2005 | 05:57 PM
19903024x4's Avatar
19903024x4
ok you say its on the tag on the axle....mine has a bunch of numbers and letters...how do i decypher that to figure my gears?
Old Apr 4, 2005 | 09:39 PM
Purple55's Avatar
Purple55
Post what the tag says and we'll cypher it fer ya.
Old Apr 6, 2005 | 04:32 PM
19903024x4's Avatar
19903024x4
S838j
3 55 88 4h10
Old Apr 6, 2005 | 04:49 PM
rclarke's Avatar
rclarke
S838J is the Ford model number for ordering parts. You have 3.55 gears and 8.8 inch ring gear. 4h10 is build date and shift info.
Old Apr 6, 2005 | 04:52 PM
19903024x4's Avatar
19903024x4
thank you much for the help
ocala562
1997 - 2003 F150
Jan 11, 2011 05:03 PM
bmacky14
Feb 28, 2010 05:59 PM
RazorbackF150
1997 - 2003 F150
20
Dec 24, 2008 11:34 PM
1978Crew
Sep 3, 2004 01:16 AM
cmrclgc
Apr 20, 2004 01:22 AM
