Look on your door sticker, it will say Axle and then a 2 digit number. Then post it here and we will tell you. Most likely you have H9, which is a 3.55 LS.
Ron, might i ask if you are familiar w/limited slip, to the point of knowingn what holds the clutch packs "tight" on ea. side. Is it just the big pin thats locked into postion with the bolt? I've read may posts where these clutch packs were factory installed too tight, causing shudder when turning curves. The reason i ask is i have just purchased a low mileage 9.75 to replace my 8.8 in a 05 scab, 4.6. Before i swap out, i had thought about inspecting/maybe replacing these clutches, but when i remove that big pin, will the side gears spring inward (after removing c clip), and have to be compressed upon re-assy? Or is it just a manufacturing tolerance build up, causing possible uneven "compression" per side? I saw you worked at Ford for several yrs. I should prob. start a new thread. thanks for any help....paul
thanks,,,,i've seen exploded veiws of the axle, and no springs in there, so i guess there just compressed in very tight at the factory, so this special tool 1) holds the side gears in place while your removing the c-clips, and 2) has a tension adjustment so you can slowy adj. the tool whichever way, to release the side gears, then you can remove all the parts? I also wanted to check the race on the axle shafts also, but maynot be able to now. BTW,,,i thought this bigger axle hsg assy would have larger outer bearings, since its a 34 spline. But i did some research on the seal and brgs for these, and there the same as 8.8, as far as i could tell by p/n's and such. So how can a larger axle (34 splines) vs 31, on 8.8, be the same diameter? Looks like only the carrier is the "heavy duty" part. thanks....paul
They do have a spring.. but not the conventional spring you are thinking of. It looks like a normal shim, but it has a slight inward curve to it, which makes it work like a spring.
The ford tool pushes the 2 side gears outward to relieve tension on the other spider gears. Which allows you to turn the carrier and remove the 2 spider gears. Kinda hard to explain, but if you seen someone rebuild one you would know what I talking about.
The 9.75 and 8.8 don't use the same bearings, the 9.75 the bearing are bigger.
Paul, what year truck did your 9.75" come from? If your going to use it to replace the one in your 05, than the 9.75" would have had to have come from a 04(new body style) or newer, due to the shock mounts are outbound.
Rich
