Transmission removal
Old Apr 5, 2005 | 07:39 PM
elemint's Avatar
elemint
Is there a correct order in how to remove an automatic transmission, driveshaft, linkage, supports, etc? Do i put a jack under the pan and then unbolt it from the engine? Thanks
67 F250
MX transmission
Old Apr 6, 2005 | 07:42 PM
savage066's Avatar
savage066
well, first you want to disconnect everything from the tranny. linkage, speedo cable, reverse sensor and anything else that might be connected. next disconnect the u-bolts on the driveshaft at the rear end. careful not to lose any needle bearings from the u-joint, cause they are a PAIN. pull the whole driveshaft out...the slip yoke can stay attached to the shaft. you may or may not have to remove the crossmember, which will necessitate that you use a jack anyway. jack it up either way, unbolt from the engine, and pull it out. it helps to have a buddy cause trannies aren't light, but i've done it all by my lonesome before. that should be all there is to it...hope that helps. if i missed anything, call me on it!
