Banks Big Head
Old Mar 31, 2005 | 08:59 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Banks Big Head
Anyone running one??? comments....
Old Mar 31, 2005 | 09:13 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Looking for comments for or against? I can tell you why you don't need one, if you're interested.
Old Mar 31, 2005 | 09:27 PM
F-250 Super Duty
Have at it, I was looking at them and didn't know if it was worth putting it on.
Old Mar 31, 2005 | 09:31 PM
cookie88's Avatar
cookie88
FTE Emeritus
It's not. You can get the exact same results the BHA would give without spending a dime. All the BHA does is increase the seat pressure on the wastegate, making it harder to open. You can adjust the pressure on your stock wastgate by shortening the wastegate actuator arm, or you can disable the wastegate completely by simply unplugging the wastegate actuator.
Robbgt's Avatar
Robbgt
why not just save the money and disconnect the wastegate?
EDIT: Cookie types faster than me...
Old Mar 31, 2005 | 09:35 PM
cookie88's Avatar
cookie88
FTE Emeritus
I wouldn't tell people that. I type with two fingers.
Old Apr 1, 2005 | 03:10 AM
Hello's Avatar
Hello
Cool grill! But your grill only has 2 thin slits. Any increase in engine temperature, or does the fan pull enough air from the bottom and sides of the grill.
Old Apr 1, 2005 | 06:53 AM
F-250 Super Duty
I have the same grill as Cookie and I have never had an increase in engine temp with it. That also includes towing horse trailers, boats and plowing snow. The two slots are the factory grill, if you look closely you'll see hundreds of little slats. It's been on for almost three years now.
Old Apr 1, 2005 | 10:28 PM
cookie88's Avatar
cookie88
FTE Emeritus
I've never had a temperature related problem through several gazillion degree Arkansas summers. Seems to flow plenty.
Old Apr 2, 2005 | 01:18 PM
johnny8's Avatar
johnny8
any probs with a stock motor if you undo the waste gate? what do you need to do if you just want to shorten the actuator arm? if you upgrade to a predator and intake/exhaust, is the modification or elimination of the wastegate going to hurt the motor..?
Old Apr 2, 2005 | 02:34 PM
Hello's Avatar
Hello
I forgot to mention I have one and it says 38psi on a label of the powerhead. But I've yet to see 15 psi since I don't tow. But the original owner said he saw over 20 psi towing. When they installed it they forgot to turn the locknut down to the end of the lever. So I did that. I tried to pull it off the turbo but couldn't. Or else I would have tried shortening the rod. Just wish that wasn't so far back in the engine so I can get to it. Really I have no idea how anyone can comfortably work on anything in the engine compartment.
Old Apr 3, 2005 | 06:13 PM
johnny8's Avatar
johnny8
i pulled off the hose going to the actuator and pluged it. maybe it's just me, but i think the mule has a little more giddyup...! i am going to shorten the actuator rod, as soon as i get a nice day, and i'm feeling like plastic man...! i sure is a tough stretch to get back in there....
Old Apr 4, 2005 | 08:43 PM
cookie88's Avatar
cookie88
FTE Emeritus
Technically, it's not more giddyup. It's just using more of the giddyup that was already there.
Old Apr 5, 2005 | 12:09 AM
johnny8's Avatar
johnny8
hey guys... i had unpluged the actuator, my mule ran a little stronger, but when i went to start it up today, (cold engine), she smoked like a damn stack, i mean really smoked...! fogged up the whole yard in just 2 mins. i shut her down, hooked that damn wastegate back up, and she stopped smokin' 30 seconds after i started her back up..... what's up with this...? what does this thing do for the motor when it's cold that keeps it from smokin'....
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
