Sponsored by: Auxito
Ceased Caliper
Old Mar 31, 2005 | 07:33 AM
primetime24's Avatar
primetime24
Ceased Caliper
Anyone got any idea how i can tell if I have a right front caliper ceased?
Old Mar 31, 2005 | 09:26 AM
FordPickupMan351w's Avatar
FordPickupMan351w
You will have an abnormal amount of brake dust in the front rim, quick wearing brake pads and usually when you are coming to a stop, the truck will pull to the right.
Old Mar 31, 2005 | 11:30 AM
primetime24
well i think i have all 3 symptoms that you described, guess it's time to pull the front wheels off and replace.
Old Mar 31, 2005 | 12:24 PM
cantrma's Avatar
cantrma
Yeah, but. A pinched or collapsed brake hose can cause the pads not to retract. A corroded slider can cause the same thing. Or the piston can be hung up, usually corrosion in the caliper cylinder. All three have the exact same symptoms.
When you first jack the tire off the ground, it will be hard to turn if any of these have occurred. Crack the bleeder a full turn, just tap (don't push) the brakes, and see if it still happens. If it doesn't, and it is just one wheel that holds, you have a bad brake line.
As you pull the pads out of the caliper, see if they slide easily. Not the pistons, just slide the pads to the inside. If not, look for dirt or corrosion that may be holding them up.
When you pull the caliper off, see if you can retract the pistons, one at a time, with a large pair of channel locks. If they're not smooth, you need a rebuild kit or a new caliper.
Good luck,
Mark
Old Mar 31, 2005 | 10:54 PM
7700Rob's Avatar
7700Rob
I just went through this. I suspected either a bad caliper, or a bad hose. I was pleasantly surprised to find corroded sliders. I was told these calipers rarely go bad when I was pricing them at the dealer. Good luck, Rob
mudadiction
Feb 28, 2006 02:33 PM
vettman
Dec 29, 2005 06:33 PM
Seatow
Dec 6, 2005 07:46 AM
Oblivion
15
Jul 31, 2002 10:15 AM
