Can Someone please do a test for me?
Old Mar 31, 2005 | 06:15 PM
rusty70f100's Avatar
rusty70f100
Well... the 344621 has 234* intake, 238* exhaust duration at .050". That's enough, isn't it?
Old Mar 31, 2005 | 06:22 PM
Annihilator's Avatar
Annihilator
Yea, and possibly more than he wants. I have heard a 395 (.030 over 390) with a Comp 280H 230/230 duration @.050 and .530intake / .530 exhaust lift and you definately knew (at least if you were a gearhead) that it had a bigger cam. Not trying to doubt you Kurt, but if the kid if going to run a Victor intake then I would think he would probably go to a Solid (mechanical) flat tappet cam or a roller of either the Hyd or Solid type. I would think a Victor would be fairly useless unless those heads had been on a flowbench and had some proven numbers. And is he going to drive the thing everyday. I will shut up now untill he posts some answers so we can get a little better idea of what his intentions are with this thing.
Old Mar 31, 2005 | 06:30 PM
rusty70f100
I definately agree with the flow bench testing. With the components we're talking about, flow through the heads will become critical. I'll wait to hear what he says. FWIW, if it's not obvious, I think this cam would work good. Crane says fair idle, not no idle.
Old Mar 31, 2005 | 07:06 PM
Annihilator
I know, but he is gonna need gears in the range of maybe 3.25's but probably more like 3.50's / 3.70's/ 3.89's. I wonder how high he is planning on turning the engine. We need to know his trans. type and if automatic he is going to definately need a higher than stall than stock converter. And he definately need to put in some different pistons (unless his block and/or heads have been shaved a lot). We need more info Fordever2....
Old Mar 31, 2005 | 07:10 PM
rusty70f100
I definately agree with this. We definately need more information. So far it's just been rough idle, and I was basing my recommendation on that and the intake he plans on using.
Old Mar 31, 2005 | 11:24 PM
Fordever2's Avatar
Fordever2
its a c6 tranny and its getting a shift kit. and i dont have the heads done yet thats why i am asking...i am trying to figure somethings out with you help.
hi-boy76
19
Jan 28, 2024 08:13 PM
Yahiko
Mar 8, 2013 02:52 AM
btravis90
Feb 8, 2012 11:24 AM
99350Ron
20
Jun 6, 2011 09:46 PM
wc46
Nov 29, 2006 08:28 AM
