Late 99 Ca. Smog test
Old May 28, 2011 | 12:29 PM
99350Ron's Avatar
99350Ron
Have to get the smog test done. I have a late 99 which has the non catalyst ca. sticker and stock with the exception of a Bully Dog Chip. Can anyone tell me what to expect when taking it for the required smog test? Thx.... Ron.
Old May 28, 2011 | 02:22 PM
Stewart_H's Avatar
Stewart_H
Some techs may look for a chip, some might not. It just depends on the facility. You can be on the safe side and just pull it for the test and then put it back on afterwards if you want.
Some facilities know what's ok (ALL aftermarket exhaust setups, ALL aftermarket intakes) and some have failed guys who have an aftermarket exhaust and intake.
Where are you located? Maybe you can find a local diesel shop and they can point you to a good smog check place that has a good tech.
Stewart
Old May 28, 2011 | 02:28 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
IDK, but I would pull that chip just to be on the safe side. And don't for get KEYS on the work bench and batteries disconnected.
Old May 28, 2011 | 02:51 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I just got my 2002 smogged. He ran it at idle for a while and checked for a CEL. Then gave it some pedal and looked for back smoke. Not even a tailpipe probe.
I talked to him and he told me that right now CA is mostly just collecting data on diesels so they know where to set the bar for future diesel smog laws.
Old May 28, 2011 | 05:49 PM
SpringerPop's Avatar
SpringerPop
Collecting data? Setting a bar?
Eggs-actly what data did they "collect" from your truck?
CEL? Yes/No
Black smoke at SNAP test? Yes/No
Lessee..... We have two bits of "data".
It's my opinion that the only thing they're "collecting" is revenue.
Pop
Old May 28, 2011 | 05:55 PM
Nick 99's Avatar
Nick 99
Did they scan for codes?
Old May 28, 2011 | 06:01 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
CEL? Yes/No
Pop
On my truck probably, since I dont have a catalytic converter. He said the newer trucks get more rigorous testing.
Old May 28, 2011 | 06:42 PM
SpringerPop
Our trucks, the 99-03 7.3s are" OBD-II Exempt", which means they might not get anything when hooking up to that data port. Since we're exempt, all they look for is a check-engine light on the instrument panel, and smoke out the tailpipe.
They also look over the engine bay for physical signs of unauthorized modifications. but turbo-back (or CAT-back, depending) exhaust mods, and air cleaner intake mods are allowed.
Which means you CAN have a 6637, but you cannot have the PCV modded to a road-draft tube.
Here's a list of can's and can'ts:
http://www.springerpop.net/F350/PDFs...%2012-2009.pdf
The last page is good reading.
Pop
Old May 28, 2011 | 09:00 PM
DON93257's Avatar
DON93257
ca smog
I took my late 99 for smog ,he told me to take 6637 off, factory box on ,he ask if i did any mod to fuel system , i said no he pluged in to obd and $40.00 and 5 minutes it was finished
Old May 28, 2011 | 09:09 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Well then he is a fool. Look at the last page of the document that SpringerPop posted. It clearly says that air intakes do not need to be checked.
Old May 28, 2011 | 09:21 PM
DON93257's Avatar
DON93257
ca smog
you are correct i smoged it april 2011 ,i'd just seen pop's post and that was the most easy smog i have ever done
Old Jun 6, 2011 | 12:00 PM
99350Ron's Avatar
99350Ron
I left the chip in and passed. He did a visual inspection and looked through a thick manual and made a phone call. He said he was checkinf the OBDII just to make sure it wasn't throwing out any codes. I have to agree strongly with Pop. This is an obvious money grab and part of doing business, living, in Ca.
Now hearing that Sacramento politicians are trying to pass a law to tax those who get a Ca. retirement and move to other states. They want to get a piece of the money even though you move out of here to avoid the Ca. tax laws. Unbelievable.
Old Jun 6, 2011 | 12:25 PM
Fat Diesel's Avatar
Fat Diesel
I don't know how long they're going to do what they're doing. My friend does smog checks and he's now forced to blow diesel smoke in the shop (and breathe it in) as he's doing the test. At some point someone's going to raise the issue to OSHA.
Old Jun 6, 2011 | 12:32 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
And they will exempt themself from that tax
Old Jun 6, 2011 | 01:00 PM
overthehillbill's Avatar
overthehillbill
Everything required by the Golden State is to keep it Golden. REVENUE ENHANCEMENT BABY!
