2000 Lightning/Eaton Supercharger Questions
Old Mar 30, 2005 | 06:26 PM
roddz170's Avatar
roddz170
Ok,
I found and bought it, it's a 2000, anything but stock.
Now I need to know how to get info on taking care of this Eaton 112- like oil levels or changing? I also notice a odd rattle sound in it at idle, maybe just the screws turning, I haven't ever heard one so I don't know. Please give me some good info on what to watch for or care for on this engine.
Eaton 112 has been rebuilt, intake and such ported and polished, aftermarket alum. water/air intercooler, 20 lb pulley set( and yes this thing pumps out WAY over 8psi of booost) I have Bassini catback, new headers,alum.driveshaft- thats what I know- I do notice a fuel cut at full tthrottle sometimes- I think it's just factory fuel cutoff at 5500rpm- runs low 12's- sounds like a mach1 jet. But in my crazy mind, I want MORE- want to buy an on-board programmer-what kind fellas? and can it change shift points, and fuel cutoff/ rpm rev limiter?
I trust cause I have got good advice here- let's do it again
Thanks
Old Mar 30, 2005 | 08:23 PM
Fredman's Avatar
Fredman
Originally Posted by roddz170
Ok,
Thanks
With the pro racers package from SCT, you can change any paramater you want to change. I think you can buy it from any SCT dealer. I don't know exactly what you mean by "on-board programmer", but with the PRP you can't change things on the fly. You change them on a PC and either flash them to the ECU with a flash tool, or burn them on a chip. Its pretty neat, and you can change anything you could possibly want to change as far as paramaters go.
Marlon
Old Mar 30, 2005 | 08:31 PM
roddz170's Avatar
roddz170
ok, heres a stupid one
who is SCT?
Old Mar 30, 2005 | 09:18 PM
Fredman's Avatar
Fredman
lol, the only stupid questions are the unasked ones.
SCT stands for Superchips Custom Tuning I believe. They probably have the best chips for ford trucks money can buy. Some more info on the Racer's Package is here:
http://www.sctflash.com/racer.php
Marlon
Old Mar 30, 2005 | 09:24 PM
roddz170's Avatar
roddz170
great, now what kind of oil for the eaton, how often to change it, and is the alen wrench screw in the front the fill to level hole?
and do you have any idea about the noise i mentioned?
Old Mar 30, 2005 | 09:50 PM
Fredman's Avatar
Fredman
Nah, I'm a turbo guy. Don't really know much about blowers. You might be able to find some info in the Lightning Forum though. Its worth a shot, just search around over there. I am sure there is someone else lurking around these boards that will be able to help you with the other questions you have too.
Marlon
Old Mar 30, 2005 | 09:59 PM
roddz170's Avatar
roddz170
thanks, i appreciate the help
Old Mar 31, 2005 | 07:42 AM
FTE Ken's Avatar
FTE Ken
Marlon
I can set you up with this. Note, however, that you should get a wide band O2 sensor for blown applications with the Racer's package. I hope you've done or plan to do bottom end work when running 20lbs boost. To get good reading of air flow which that much boost I suggest SCT's MAF or Diablo's Mafia so you don't peg the meter.
Old Mar 31, 2005 | 07:58 AM
roddz170's Avatar
roddz170
Great , thats something I'll check on. It's hard to say whats all the mods on this, since I did not build it. I do know what I can see and feel, like a 10psi boost gauge pegged and bouncing at 12lbs - I'm going to get me a new one SOON so I know for sure.
I don't notice any real problems spots in power, but an occasional hickup at what I believe is the rpm limit for ffuel shutoff- which I hate cause I'm scared of a backfire blowing a piston through the pan,lol.
My only other problem is a trans that can't find a exact shift point, I think due to bad chip program in which it's trying to base shift points on driver (feel) , we know ECU can't read our adreniline levels no matter how bad the manufacturers want to try to sell the SMART AI, LoL!
Old Mar 31, 2005 | 11:48 AM
Fredman's Avatar
Fredman
If you want something cheaper than the pro racers package, you can opt for the SCT X-calibrator flash tool, and download the SCT Extreme tune software (its free to download). With that you can change tire sizes, rear gear ratios, all shift points, torque converter lock and unlock schedules, add 2 degrees timing and retard 5 degrees, set rev limiter and speed limiter, set shift firmness, change idle rpms, and set fuel trims at idle, part throttle and wide open throttle. Its what I have for my turbo truck, and I like being able to change that stuff, but not get too complicated like the racers package is.
Marlon
Old Mar 31, 2005 | 08:56 PM
roddz170's Avatar
roddz170
that sounds good, I know immed. good could come with some stronger shifts, and a bit of tourqe converter stall!
Gicknordon
24
Mar 27, 2015 01:02 PM
Gerby Dutchy
2009 - 2014 F150
Nov 14, 2014 01:54 PM
lasitter
Jun 13, 2014 12:32 PM
Brian3676
Jan 10, 2011 05:50 PM
Greywolf
General Automotive Discussion
Oct 30, 2006 01:30 AM
