Sponsored by: Real Truck
Eaton True track rear diff
Old Jan 10, 2011 | 11:28 AM
Brian3676's Avatar
Brian3676
I have a 2009 F 450 with the 6.4L. Currently have a Dana S110L limited slip diff. I want to put in a Eaton True trac rear diff, However Eaton is telling me they are not sure if it will work due to the oil differences. It will psychically fit, but possibly not work. I see my truck uses a synthetic from the factory, and Eaton tells me unless I put a regular oil in with there diff, then it will not lock up. So since I am swapping out the diff for the Eaton, can I use regular oil? Or will that destroy the bearings and other components on the rear end?
Summery-
Ford calls for synthetic oil if I put the Eaton rear diff in, can I put in regular oil like they call for.
Old Jan 10, 2011 | 12:45 PM
SuperDutyScaler's Avatar
SuperDutyScaler
im not sure but if their diffs work in 250 and 350 with synthetic oil why wont it for in the 450 and 550 axles?
Old Jan 10, 2011 | 01:21 PM
FE Doug's Avatar
FE Doug
I put an eaton true trac in my 04 f350 v10 before winter used syn. oil, works great!
Old Jan 10, 2011 | 03:39 PM
2006lariat's Avatar
2006lariat
Summery-
If the lube matches specs, I would run it! Synthetics are made for less maintenance intervals. To me all that means is it protects longer, and may handle heat better, for longer. On that note, I ran Synthetic with my TruTrac on my 9.75" rearend on my F150! (I know it wasnt under the stress and weight of your 450). On another note, you could try it with synthetic and dino, and see what works better! I am betting that it will work fine with the synthetic!
Old Jan 10, 2011 | 05:50 PM
rbaker6336's Avatar
rbaker6336
It won't hurt bearings or gears to run regular gear oil
dog2580
1997 - 2003 F150
Jun 30, 2016 08:44 AM
dog2580
1997 - 2003 F150
Jun 21, 2016 08:59 PM
Ranger1F150
Jan 24, 2009 11:29 AM
Munkey
May 20, 2008 03:40 PM
eco
Apr 3, 2007 05:34 AM
