Left Front Tire Cupping
Old Mar 28, 2005 | 08:36 PM
edub32's Avatar
edub32
I have an 01 PSD and on my front left tire the tread on the tire cupping..I'm pretty sure it comes down to either a bad left front shock or bad left front rotor or pad..Anyone have any other ideas or know how I can tell which one is causing the problem?
Old Mar 28, 2005 | 08:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
An out of balance tire can cup also. You may have just tossed a wheel weight.
Old Mar 28, 2005 | 09:56 PM
oldbird1965's Avatar
oldbird1965
Me Too
My 96 does the same thing. The front left cups on the outside of the tire. My alignment guy said its a 'Ford thing'. A couple of hundred to fix it.
Old Mar 28, 2005 | 11:02 PM
rirwin's Avatar
rirwin
I'd have to go with shocks on this one. It is a Ford thing. Crappy OE shocks. Just my opinion.
Old Mar 29, 2005 | 11:23 AM
Barnacle Bill's Avatar
Barnacle Bill
My 96 350 does the same on the outside of the left tire. It's been like this since my sister wacked the left wheel while off-roading and screwed the alignment. The truck and shocks were only a couple of years old then.
Also even after two alignments the steering wheel is turned 20 degrees to the right when going straight. I asked my mechanic to adjust the alignment to straighten out the wheel. He said it couldn't be done.
Seems to me the steering wheel should line up and the road wheels should be straight.
Finally, how do you test shocks on a 7000lb truck. I used to bounce my MGB by leaning on it.
Old Apr 5, 2005 | 07:49 PM
edub32's Avatar
edub32
Well, it turns out the reason the left tire was cupping was because my outer tie rods and centerlink are froze up and its going to cost $500 to fix and have it aligned...hope this helps someone in the future
Old Apr 5, 2005 | 07:59 PM
superrangerman2002's Avatar
superrangerman2002
I've gotta raise the BS flag on that!
I've never heard that before.
I'd bet who ever looked at it didn't have a clue, and arbitarily decided to replace a bunch of stuff.
Usually steering problems cause both tires to scrub, not just one. Ball joints on the other hand can cause one tire to cup and not the other. My money is on the ball joints being out of whack on that side.
madpogue
Jun 28, 2014 10:44 PM
kush1972
Jan 25, 2014 06:27 AM
nomad221
Aug 1, 2013 11:49 PM
richard1586
1978 - 1996 Big Bronco
Aug 29, 2006 03:44 PM
huckster
Jul 29, 2003 06:01 AM
