TURCK STALLS!!!!!!!!!!!!!!!!!!
Old Mar 9, 2001 | 12:10 PM
zemus420's Avatar
zemus420
My 85' Ford F-150 .302 engine Automatic keeps stalling out. When I approach a stop and get ready to take off I step on the gas peddle and it stalls out on me it also does this on turns can anyone give me some advice to solve this problem
Old Mar 9, 2001 | 07:08 PM
freeway's Avatar
freeway
This same problem has plagued me for several years and I have spent much money and time trying to fix it. In essence, I have replaced every part that could have caused the problem and I just about have it licked.
My first thought was carburator, I have a holley 4 barrel. I had it rebuilt a few years ago, so I just replaced it with an aftermarket Holley. The car ran better, but it still stalled when I gave it gas. I set the floats so the gas just trickles out the sight hole, and it still did not work.
I changed the fuel pump - it was only a few bucks but it made no difference at all. BTW I get 8 on my gauge for pressure.
I searched for a vac leak and found none.
Then the bronco died and did not start. After the process of elimination, I found out my timing chain had slipped. Turned out it was real loose, I replaced it and set the timing again and the hesitation was all but gone! Good Luck.
Dan
85 Bronco
351w H.O.
Old Mar 9, 2001 | 10:43 PM
jakegypsum's Avatar
jakegypsum
Check the EGR valve. I have seen similar situations with this being the culprit. Check vacuum and actual operation of the valve. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old Mar 10, 2001 | 01:40 AM
knuckles's Avatar
knuckles
jduggan43
Sep 30, 2013 10:29 AM
ellsdemon
Dec 29, 2006 10:18 PM
jsphsol6
Nov 13, 2006 04:16 PM
Tiny1104
Aug 19, 2005 10:02 AM
