General Automotive Discussion
Compression numbers
Old Mar 26, 2005 | 04:26 PM
polar88's Avatar
polar88
Question compression question
What is the general compression range of a mid-time chevy 350? My brother and I are argueing that his 137 psi average is low, he says NOT. What would a new motor run? We took out all 8 plugs and then did an average. He thinks his lack of power is due to something else, maybe rocks in his head.
Thanks
Old Mar 26, 2005 | 04:29 PM
polar88's Avatar
polar88
Question Compression numbers
I'm in an arguement with my brother about the reason for his lack of power in his suburban. It is a chevy 350. His average compression # 137. I say it's low, he says it's mid-time. What is new? What is mid-time, and what is worn out? Thanks
Old Mar 26, 2005 | 05:03 PM
captchas's Avatar
captchas
Guest
how about a little more info. what was highest and lowest. year of motor, that could be worse but it should run with that.give us a bit more input so some old time brain matter can work.
Old Mar 26, 2005 | 06:13 PM
SSCX2's Avatar
SSCX2
Well compression ratio for stock piston stock 76cc headed chevy 350 is 8.5:1.
137 PSI per hole was that a warm reading or cold? A fresh engine with factory ring gap @ operating temp will be 200 PSI+. So what your getting if the pressure was taken cold is a good engine, if it was taken @ temp it's still a good engine well above spec.
Whats the engine doing, just lack of power, how much lack of power?
Old Mar 26, 2005 | 10:22 PM
Overkill-F1's Avatar
Overkill-F1
If the eight compression values are plus or minus 10% or so, I'd say they are fine. 150 lbs is an average/good pressure. ...Terry
Old Mar 27, 2005 | 01:25 AM
Icicle's Avatar
Icicle
perhaps his lack of power comes from the fact that thats a LOT of weight for a 350 to move around.
you picked a weird forum to put this question in.......
Compression readings have a lot to do with the CR of the motor, which we dont know, so its hard to say if they are low or high, but they arent too bad, consistency is more important, is that a dry compression test I assume as opposed to a wet test?
Old Mar 27, 2005 | 01:45 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to General Automotive, threads merged. Non Ford engines are not covered in the Ford truck tech forums.
Old Mar 27, 2005 | 04:39 AM
tmyers's Avatar
tmyers
Well if static compression ratio is 8.5 then you would have around 156 PSI new. This is according to EA v3.0
AKHunter93
Nov 21, 2015 04:20 PM
Vinford
6.4L Power Stroke Diesel
Jul 12, 2015 06:36 PM
Four.on.the.floor
Apr 6, 2015 07:14 PM
Kalabin
Modular V10 (6.8l)
67
Apr 6, 2015 11:49 AM
Toreador_Diesel
Sep 11, 2014 01:00 AM
