Sponsored by: Auxito
Sag
Old Mar 28, 2005 | 08:18 PM
malbojah's Avatar
malbojah
Originally Posted by B_7700_4X4
Only coil over shocks or air shocks help support. It's a spring problem for sure. Alot of F150's have the have misaligned rear springs especially if you take your truck offroad. If I were you I would start by fixing that problem and then continue from there if necessary. Good luck
I had some AirLift air bags installed to help with towing and my truck still sags on the left side. Was kinda hoping that it would help
Old Mar 28, 2005 | 08:32 PM
Racerguy's Avatar
Racerguy
malbojah you can split the air lines so you can pump up each side individually to level it out.
Old Mar 28, 2005 | 09:05 PM
malbojah's Avatar
malbojah
Wouldn't I need to get a second controller to do each line? ( or a dual controller?)
Currently its 1)compressor, 2) controller and low pressure sensor, 3) air line split under bed, 4) bag on each side, 5) relief/refill valves on corners of rear bumper for both bags
Old Mar 28, 2005 | 09:14 PM
dilas's Avatar
dilas
On my 98 F150, I had the left rear spring slightly bent, resulting uneven height on rear end on both sides. Had both rear springs replaced, and it evened it out. Interesting, the Firestone shop didn't notice it when I replaced the tires with new Bridgestone Duelers when they had trouble aligning the wheels. I took it to different shop, and this expert guy said I needed to replace leaf springs to even it all out and it'll align properly without any shimming added.
Check out the rear springs first, before doing the shocks.
Old Mar 28, 2005 | 09:57 PM
Racerguy's Avatar
Racerguy
malbojah I didn't realize you had an onboard compressor. That does complicate things.
I'm used to seeing systems just with valves that stick a tire chuck on.
voodood
1983 - 2012 Ranger & B-Series
May 22, 2010 09:49 AM
ncinirator
Paint & Bodywork
Jul 14, 2007 02:13 PM
Chas1234
Feb 22, 2003 09:55 PM
buzzard
Aug 8, 2002 07:36 AM
jwtaylor
Nov 19, 2001 08:44 PM
