load leveling suspension rear sagging
Old Mar 25, 2002 | 09:24 AM
buzzard's Avatar
buzzard
Old Aug 8, 2002 | 07:36 AM
slickwilly's Avatar
slickwilly
4wd Low
I have a 97 with LLS and rear end is just about dragging on the ground. The compressor is not going on to pump up the rear. I tested the compressor by sending power to it directly and it is still operates. Is there any way to test the ride height sensor with a multimeter? Finally the check suspension light has turned on. I am having that checked today. Has anyone had any similair problems with the compressor, height sensor or solenoid valve assy? Thanks,
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
