Code P0272
Old Mar 25, 2005 | 09:12 PM
bob6.0's Avatar
bob6.0
Code P0272
Have had a rough idle occasionally while sitting at stop lights for about 1 1/2 weeks, finally took the truck in (wednesday) and they replaced the EGR and reflashed truck, in which the truck ran fine until this afternoon the rough idling started again only somewhat worse. Managed to scrounge up code reader and got a P1000 and a P0272. P0272 states "Cylinder 4 Contribution/Balance Fault". Can anyone tell me what this means? Also my dealer made no mention of any other concerns other than the reflash and the EGR. I would think that if I have the same symptoms today as I did on Wednesday, should'nt they have seen this code on Wednesday also? If this is a difficult fix, maybe they are giving me the run around.(Just thinking out loud). Still have all 8 original C94 injectors also. Any help would be appreciated.
Old Mar 25, 2005 | 10:48 PM
huntercgr's Avatar
huntercgr
I had a PO263 code which was a bad #1 injector that they replaced.
Old Mar 25, 2005 | 11:42 PM
SBV45's Avatar
SBV45
Cylinder 4 Contribution/Balance Fault means that your number 4 cylinder is not firing the way it should compare to the other 7. There could be a number of reasons for that, injector being one of them. Sounds like you might want to try another service department.
Old Mar 26, 2005 | 10:29 AM
bob6.0's Avatar
bob6.0
I'll give my dealer one more shot at it, should I let them know that I know what the codes are or should I just play dumb and see if they try to fix it?
Old Mar 26, 2005 | 11:28 AM
sanpanchosue's Avatar
sanpanchosue
Originally Posted by bob6.0
I'll give my dealer one more shot at it, I should I let them know that I know what the codes are or should I just play dumb and see if they try to fix it?
I had a bad contribution/balance code on #6. Now have 5000 miles on a new engine.
Old Mar 26, 2005 | 11:48 AM
bob6.0's Avatar
bob6.0
Sanpanchosue, what did they do to fix your problem?
Old Mar 26, 2005 | 11:52 AM
jim6liter's Avatar
jim6liter
It looks like he got a new motor.
Old Mar 26, 2005 | 12:40 PM
sanpanchosue
Yup, took them 3 weeks to install it mostly due to one problem or another with Ford Canada.
Old Mar 28, 2005 | 06:38 PM
bob6.0's Avatar
bob6.0
For some reason they finally agreed that there was a problem when I told them that I had discovered a code. They are replacing #4 injector.
Old Dec 12, 2021 | 11:37 PM
saleenstang's Avatar
saleenstang
Ficim
it’s you’re clips on you’re ficim the one closest to the firewall
Old Dec 13, 2021 | 12:19 AM
Ford.Dude's Avatar
Ford.Dude
And the award goes to.......
Oldest thread revival I've seen since I've been lurking around.
AJB201
Oct 26, 2012 10:14 PM
jkinghorn6.0
Sep 27, 2011 10:42 PM
Brian460
Aug 16, 2011 02:44 AM
BENNY1066
Aug 15, 2008 08:33 PM
davidwruth
May 27, 2008 07:41 AM
