Jumpy gas gauge?
Old Mar 20, 2001 | 05:21 PM
fool4fords's Avatar
fool4fords
Jumpy gas gauge?
hi everyone! My ford has a problem with a jumpy gas gauge. The meter just kinda "flows" back and forth across the gauge window. It seems to sometimes "settle" it what might be somewhat of a correct reading, but not sure. Anyone out there ever have this kinda problem? It wouldnt be such a big deal, but the nearest gas station is about 25 miles away. Thats wide open West Texas for ya!---------> pcline
99' f250 Powerstroke
99' e150 econoline
88' f150 V8 - 302
Old Mar 20, 2001 | 07:12 PM
fatforty's Avatar
fatforty
Jumpy gas gauge?
Hi, it sounds like you have an intermittant ground problem check the ground wire at the sender pull it off and clean it up with a piece of sand paper and reinstall it see if this helps it. John
Old Mar 21, 2001 | 01:10 AM
hotrodford_88's Avatar
hotrodford_88
Jumpy gas gauge?
Old Mar 21, 2001 | 09:33 AM
noremac19's Avatar
noremac19
Jumpy gas gauge?
Ya my 94" F150 does the same thing. The gas gauge moves when turning corners, stepping on it, or braking. Once my gauge settles its accurate. Dont worry about anything
Old Mar 21, 2001 | 10:12 AM
Franklin2's Avatar
Franklin2
Jumpy gas gauge?
If the other guages vary some too, it could be the instrument regulator on back of the guage panel.
Old Mar 21, 2001 | 11:04 AM
bjoern's Avatar
bjoern
Jumpy gas gauge?
I have the same thing - on one of the tanks. The other always shows empty :-)
1988 F-150, 5.0L 302ci, 5spd, SuperCab. Shorty headers, K&N filter, Accell 300 8.8mm race wires, Accell supercoil, Accell rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: MSD 6a ignition and dual exhaust.
Old Mar 21, 2001 | 04:56 PM
mrlaserboy's Avatar
mrlaserboy
Jumpy gas gauge?
It's actually the fuel level sender in the tank. Not quite sure how to explain this but the sender is like a slide potentiometer with a wiper rubbing against a resistance film (this is the part I can't explain clearly). But anyways, over time the wiper wears out the film and grounds itself out resulting in a bouncing gauge needle. On mine, I can tell mine is worn out from 3/4 of a tank to 1/8 of a tank. The needle works just fine when full and almost empty but when it's anywhere in between 3/4 and 1/8 of a tank, the needle pegs out. Only fix to this problem is a new fuel level sender.
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.superford.org/users/ylobronc/index.html
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift/2" BL/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER http://www.2bigbroncos.org
Old Mar 22, 2001 | 07:20 PM
KevinT's Avatar
KevinT
Jumpy gas gauge?
I'm not sure on your guy's problem, but mine will drop down to 1/4 tank when I do a nice pedal to the metal, quick shifting, when getting on the freeway or leaving my house (street in front of my house, speed limit=55) even with a 1/2 full tank it will drop down to 1/4 tank if I floor it for a bit, but after 20-30 seconds of normal driving it goes back up to where it was before, I dunno but I think its just the gas sloshing around
1995 F-150XL SC/SB
http://members.sounddomain.com/blind
5-Star Rated F-150 (Big Stereo)
J ballan
May 6, 2012 09:37 PM
plcrsn73014
May 17, 2011 06:30 PM
78bigunns
Offroad & 4x4
Jul 1, 2008 09:05 AM
Ford Freak
1997 - 2003 F150
Mar 31, 2004 08:24 AM
