Sponsored by: Auxito
Need help with Speedometer Sticking
Old Mar 30, 2004 | 11:05 AM
Ford Freak's Avatar
Ford Freak
Question Need help with Speedometer Sticking
What a great site!!! I'm new here and have a question about the speedometer on my 99 F150 4x4 (4.6L). It has 169,000 miles and my speedometer is sticking. It is very jumpy from 0 to 40 and then it just sticks on 40mph when I accelerate above that speed.
It just started happening last night. I'm not sure if there is something simple that I need to check? Am I causing further problems by driving it over 40mph with it stuck?
Thanks.
Old Mar 31, 2004 | 12:05 AM
Racerguy's Avatar
Racerguy
Hi Ford Freak and welcome to the forum
I dont think you're hurting anything by driving it like that. Does the transmission shift ok still (if it's an auto)? If it shifts ok then the speed signal is getting to the PCM ok and your problem is probably the speedo itself. I doubt it could be fixed. It would probably have to be replaced.
Old Mar 31, 2004 | 08:24 AM
Ford Freak's Avatar
Ford Freak
Thanks Racerguy...It is an Automatic transmission and seems to be shifting OK. The speedometer works up to 40mph but will not go any higher.
I'll check around on getting it replaced.
rylowe
Feb 28, 2015 04:45 PM
smokeywagon
Sep 4, 2014 09:20 PM
darren_palms
Jul 14, 2014 11:02 PM
marragtop
Mar 18, 2009 10:40 PM
DougD
May 24, 2004 11:54 PM
