Fuse #45
Old Mar 23, 2005 | 01:29 PM
mboegler's Avatar
mboegler
Fuse #45
My 2002 F250 7.3 PSD is blowing the #45 fuse every once in a while. It will blow factory installed 10 amp and a 15 amp. When this Happens the dash goes dead and you can't accel the engine. If you replace the fuse it will last for a couple of days. It seems to happen during the start. Could this be part of the electric adjustable pedal recall? Or a short somewhere else?
Old Mar 23, 2005 | 01:59 PM
wlihntr's Avatar
wlihntr
in your manual, what does it list that fuse controls?
Old Mar 23, 2005 | 04:25 PM
mboegler's Avatar
mboegler
Instrument cluster power start/run.
Old Mar 23, 2005 | 07:38 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Did you check the wiring in the steering column. That seems to be what fixed AutoDoc's. His post is nearly identical to yours. Popping fuses like that almost always means a short somewhere.
Old Mar 23, 2005 | 08:27 PM
mboegler's Avatar
mboegler
Thumbs up I fixed it
I opened up the column and found the wires from the o/d button on the shift lever chaffed and shorted out on the column. I put heat shrink on the wires and reposssioned them.
Thank You Doc
Mike
Old Mar 24, 2005 | 12:29 AM
SpringerPop's Avatar
SpringerPop
I LOVE reading one-day stories like this. Seven hours later, his problem was fixed! And he learned something about his truck. He learned something about the folks here, too.
SpringerPop
F-WhiteThunder
May 23, 2014 08:49 PM
roscoewalsh
1997 - 2003 F150
Feb 6, 2011 08:27 PM
njstevens
Dec 27, 2007 09:39 PM
highboy390fe
Nov 30, 2007 01:50 PM
blhotrod
New Member Introductions
Jun 18, 2007 11:02 AM
