Blowing Fuses
Old Nov 30, 2007 | 08:54 AM
highboy390fe's Avatar
highboy390fe
Blowing Fuses
My cousin has got a 99 f250 7.3, his truck keeps blowing 30 amp fuses and when it does the whole truck shuts down. I think its fuse number 30 its the farthest to the right and the very bottom 30 amp fuse. Its for the pcm and some other things. The place where you slide it in is kind of worn out almost and when you puch down on the fuse to get a good connection it will start but as soon as you start to crank and move the fuse a little bit it will blow and shut off. Has anybody ever had this happen tp them before. Any help would be appreciated because the truck is sitting on the side of the road and has gone through about 20 fuses. Thanks.
Old Nov 30, 2007 | 10:16 AM
cgl's Avatar
cgl
Fuse # 30 controls the ... PCM Relay Coil, Ignition Coil (Gasoline only), Fuel Heater (Diesel only), Wastegate Solenoid (Diesel only), Injector Driver Module Relay Coil (Diesel only)
SO... I'm willing to bet it's your fuel bowl heater that has shorted out. Try unhooking the connector on back of the fuel filter housing, below the yellow drain valve. Then replace the fuse again. That should get you back on the road. You can later inspect the heater element by removing the filter and looking at the bottom of the bowl.
Old Nov 30, 2007 | 10:26 AM
highboy390fe
ill give it a try and see what happens
Old Nov 30, 2007 | 01:18 PM
Superduty krazy's Avatar
Superduty krazy
I just had that same problem it was the heating element....
Old Nov 30, 2007 | 01:50 PM
highboy390fe
thats good to hear thanks,Thats why i love this website, makes my life easier, considering I'm going to be the one to have to fix it.
thomm
Oct 31, 2011 03:00 PM
cs10racing
Electrical Systems/Wiring
May 12, 2011 09:48 PM
73f100shortbed
Bronco II
Jul 18, 2006 06:50 PM
OrangeF150
1997 - 2003 F150
Aug 8, 2005 10:49 PM
cberster
Jan 27, 2004 08:27 PM
