what is highboy
Old Mar 23, 2005 | 09:19 AM
Mikestrucks's Avatar
Mikestrucks
what is highboy
or more exactly, what is the deiference in the beds? I hear all kinds of rumors about highboy vs normal fleetside beds? I think it's all hogwash but what is the real story? Did ford really make a special bed for such a small aplication! Anyone know? And if it is a special bed, what is so special about it? Can I make a standard fleetside work?
Old Mar 23, 2005 | 09:24 AM
Mikestrucks
reply to your question from your own self
If you can read this, you are talking to yourself. Now go to work and let the other people on this site help you!
Old Mar 23, 2005 | 09:51 AM
nebechanezer's Avatar
nebechanezer
a highboy is a ford f-250 4x4 from 67-77.5 . the frames are narrower on these trucks than some others, so i would guess the mounting holes in the bed would be closer together than other trucks, otherwise i think the beds are the same.
Old Mar 23, 2005 | 10:03 AM
fordfury469's Avatar
fordfury469
i have a 78 bed on my highboy had to re locate the moutning holes because of the narrower frame but they will work, a little mod and it fits right on.
Old Mar 23, 2005 | 12:51 PM
Mil1ion's Avatar
Mil1ion
Maybe read this ?
https://www.ford-trucks.com/forums/s...d.php?t=358616
Old Mar 23, 2005 | 01:12 PM
Mikestrucks
Hey, thanks Fordfury and everyone else. If I may ask, how much difference did you have to make? In other words will it let me put the new holes in the bottom flat parts of the floor between the ribs or will the holes wind up being up on top of the floor ribs or some other less than nice location?
Old Mar 24, 2005 | 08:03 AM
fordfury469
there only like 2 inches difference. to the inside.
Old Mar 24, 2005 | 11:59 AM
MHull's Avatar
MHull
Just so you know- I definitely know that they continued the High-Boy in into 79, because my dad has one!
Old Mar 24, 2005 | 12:21 PM
150ford's Avatar
150ford
Nah the highboys ended in mid 1977. So if its a 79 a lift was probably put on it. It didnt come from the factory that way. Highboys have arched springs in the front as well as back.
Old Mar 24, 2005 | 12:46 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
78-79 4x4s are referred to as lowboys, i know because that is what my 78 4x4 is, Ford switched to inverted front springs halfway through 77......like 150ford said, someone put different springs on the front....
Old Mar 24, 2005 | 09:13 PM
bottlefedchevy's Avatar
bottlefedchevy
i have a 78 f-250 with lift blocks in the rear that are factory....so its not a highboy??
Old Mar 24, 2005 | 09:27 PM
SwOkcOffRoader
nope, my 78 F-250 has the same thing, the "highboy" nickname was given to the pre-mid 77 4x4's for their tall stance of the front suspension from the factory.......
Old Mar 24, 2005 | 09:29 PM
bottlefedchevy
so do you know the reason for the blocks?...just an option or a standard thing?
Old Mar 24, 2005 | 09:39 PM
150ford's Avatar
150ford
Probably a standard thing the highboys had arched front and back springs that gave them the extra height. Put the two side by side and you would definitly see the difference. A friend off mine has a highboy 1977 model that he still uses. I really like that truck. A friend off mine has a 79. Maybe I could get pictures off the springs for you guys sometime.
Old Mar 24, 2005 | 09:49 PM
SwOkcOffRoader
here is a pic of somebody's highboy that i found in the galleries....
https://www.ford-trucks.com/user_gal...?&albumid=8964
here is a pic of my 78 F-250 "lowboy" dont mind the ugly body, its all gonna be replaced soon, note how the front of my truck points down while the Highboy above sits nice and level.....thats due to the inverted front springs they put on my truck from the factory....as for the rear blocks, i have been wondering about them as well.........
https://www.ford-trucks.com/user_gal...&albumid=13882
