what is highboy
Old Mar 26, 2005 | 07:26 PM
  #31
squeezer's Avatar
squeezer
Originally Posted by big_i80
Uh sqeezer I beg to differ on the payload option. The highboy's (pre77.5) have a narrower frame and have more crossmembers than a post 77.5. This yields a frame that is capable of higher stresses, ie torsion and bending.
Wrong...
The frame does not determine the ultimate limit of payload capacity.
The wider frame allows for a wider spring and shock stance which of course gives a more stable ride given the same spring rate.
Next...
Old Mar 26, 2005 | 07:30 PM
  #32
big_i80's Avatar
big_i80
You never said anything about stability, and yes a highboy frame is more resistant to torsion. Don't believe me, take 2 2x4's 1 10 feet long and 1 3 feet long and try to bend both. Tell me which bends more.
Old Mar 26, 2005 | 07:59 PM
  #33
squeezer's Avatar
squeezer
yea yea first year Engineering...
Neither one of those chassis has a weak frame. If you break the frame on either of those trucks you are operating so far outside any reasonable limit as to not be worth talking about
Again I would like a real example of how a higboy is better.
And for the record I have owned and worked both chassis types for hundreds of thousands of miles
Old Mar 26, 2005 | 08:04 PM
  #34
nebechanezer's Avatar
nebechanezer
If you are arguing about payload of the highboy to a 77.5-79, then it could be settled by checking factory specs. comparing frames doesn't include the rest of the truck, if you are comparing payload capacity.
Old Mar 26, 2005 | 08:57 PM
  #35
fordfury469's Avatar
fordfury469
ok again tell me why we are argueing about two of fords best pickups.
Old Mar 26, 2005 | 10:44 PM
  #36
MHull's Avatar
MHull
LOL, point taken fordfury469. I like to think that a spirited debate warms the blood on these cold nights. Only problem is that its not that cold here, oh well!
Old Mar 27, 2005 | 12:48 AM
  #37
Cheapevil's Avatar
Cheapevil
Hey squeezer here in CA 75 and older Highboys are the best cause you ain't got to to deal with the FN smog every other year. So you can run what ever you want. With that said everything else you listed is spot on.
Old Mar 27, 2005 | 11:26 AM
  #38
150ford's Avatar
150ford
I like them all.Hey its a Ford. High or low there all great. Im gone for awhile and look at all the bickering going on.
Old Mar 27, 2005 | 12:57 PM
  #39
fordfury469
I like both years 73 to 77 and 78 to 79 i have owned botha a 79 1/2 ton with 4 inches lift 35 and a 429 locked up all the way around. now i own a 76 highboy 4 inches of lift over stock and 35 i like them both of course i got the highboy after some one else tried to screw it up so im stuck fixing his mess ups, not to many highboys around with ac cruise and delay wipers. and true power steering. and soon to be a 429 in it too. i really like the hieght over the 78 and 79 though
Old Mar 27, 2005 | 04:37 PM
  #40
SwOkcOffRoader's Avatar
SwOkcOffRoader
my 78 might be a "lowboy" , but it wont be low when i get done with it, its getting about 4" of lift for now...........until i purchase everything to 4 link and airbag it then ill have 4-15"s of lift on demand!!! lookout highboys, the 78-79's are stepping up!!!!!!!!
Old Mar 27, 2005 | 05:00 PM
  #41
olfordsnstone's Avatar
olfordsnstone
Highboys are better cause I like em better. Just kidding. I do prefer the highboys as this was Fords classic immage for so many years. Chevy and Dodge had some nice looking trucks for a while, all sittin up there, but Ford kept the tradition. Longer front drive shaft etc... I just think that "4X4 TRUCK" YELLS AT YA when you see one of these beasts. Now, if you guys wanna try to mimick what just came natural for the highboys, I guess I can understand how you would want to look like that. Rant rant rant...
No really, I AM just kidding, it is all good. Fords just kick butt!
Old Mar 27, 2005 | 05:37 PM
  #42
77300i6's Avatar
77300i6
A good friend of mine has a '79 4x4 sb that he put 35's on. It only rubbed a little when hitting very hard bumps or with the wheel at full lock in reverse. I has a 4" lift on it now, so there are no probs. I NEVER would have guessed that 35's would fit on a stock truck. Try doing that with a cheby!!
Old Mar 28, 2005 | 07:44 AM
  #43
fordfury469
my 35 rubbed on my radius arms and my headers with 4 inches of lift.
Old Mar 28, 2005 | 09:21 AM
  #44
squeezer's Avatar
squeezer
Just for clarity...
If you have a short box, your truck is not a highboy...
If you have radius arms, your truck is not a highboy...
if you have 5 lugs on anything, your truck is not a highboy...
Highboys are characterized by 3/4 ton (only), divorced T-cases (only), ram type power steering (only).
Old Mar 28, 2005 | 08:59 PM
  #45
fordfury469
squeezer i was just answering 77300i6. nothing to do with a highboy i know what a highboy is. matter of fact i have one and you say ram type power steering what abotu no power steering.
