View Poll Results: Is LUCAS heavy duty oil stabalizer all its cracked up to be?
yes
60.00%
no
40.00%
Voters: 5. You may not vote on this poll
valve adjustment
Old Mar 21, 2005 | 12:14 AM
retrogod1's Avatar
retrogod1
valve adjustment/LUCAS oil good?
So when I get my vacuum problem figured out I need to do a valve adjustment, but I don't know how tight to make 'em. I hear them chatering under the cover well especially one in paticular in my '68 f250. also I wonder about putting that LUCAS wonder oil in my truck anybody know of it.
Old Mar 21, 2005 | 12:32 AM
xlt70black's Avatar
xlt70black
Valve adjust
68 F250 Im guessing 360/390 if so NON ADJUSTABLE.
Old Mar 21, 2005 | 01:00 AM
retrogod1's Avatar
retrogod1
Wow I did'nt know that there were non adjustable valves. that sucks for me oh well
Old Mar 21, 2005 | 09:30 AM
Unimog005's Avatar
Unimog005
Make sure your oil is full.......the hydraulic lifters won't "pump-up" without adequate oil pressure and you'll hear them tap more....if it persists, my guess would be you have a collapsed lifter....meaning it can no longer "pump-up" for some reason.
I didn't realize that the valves were "non-adjustable." Can anyone claify this, because I have found MORE than ONE source detailing how to adjust these valves.
Old Mar 21, 2005 | 04:14 PM
SRD4X4's Avatar
SRD4X4
There is a sequence to tightening the rail on FE's other than that,no adjustment.You can get different length pushrods to compensate for any excess lash though.But you have to find out where the extra play is,i.e.collapsed lifter,worn cam,"sunken" valve,etc.There are also adjustable pushrods,but I haven't seen them in awhile.
Old Mar 21, 2005 | 06:08 PM
71swissaqua's Avatar
71swissaqua
You'll see refence to valve adjustment in the shop manuals and Chiltons etc, due to the earlier 289's having an ajustable valve train. use ti throw me also
clint
Old Mar 22, 2005 | 08:01 PM
baitmaster's Avatar
baitmaster
pushrods
SRD is right with the longer length pushrods. yrs ago when my 100,000m 390 starting clicking, I pulled the valve covers and with the engine running found out which ones had "play" in them. Went to the parts store and bought a few that were a tiny bit longer and replaced the worn ones. Make sure the ones that you reuse go back in the same place. All the noise went away and I drove it for another 5 yrs before rebuilding another 390. BTW, your rocker arms can wear too, with new 390 I installed all new valve train for about $125.
JayzDaddy
May 29, 2014 05:00 PM
Fordman2822
Feb 19, 2011 05:05 AM
reifwj
29
Apr 22, 2008 09:13 AM
78RangerXLT
Sep 9, 2003 05:04 PM
