5.0L valve adjustment
Old Feb 18, 2011 | 04:24 PM
Fordman2822's Avatar
Fordman2822
I was wondering if anyone knows the specs and procedure for adjusting the valves/rocker arms on 5.0L out of a 94 f150. Rocker arm torque specs? Thank you for the help!
Old Feb 18, 2011 | 06:05 PM
lew52's Avatar
lew52
The valves are non adjustable , the rocker arm torque specs are 18-25 ft-lbs....Lew
Old Feb 18, 2011 | 06:08 PM
Fordman2822
I don't have to set clearance between rocker arm and valve?
Old Feb 18, 2011 | 06:55 PM
lew52's Avatar
lew52
With the stock E7 heads , no , the lifter preload is built in to the rockers when you tighten them down , there pedastal mount rockers....
Old Feb 18, 2011 | 06:59 PM
Fordman2822
Thank you for the advice I had no idea
Old Feb 19, 2011 | 05:05 AM
Slip ford man's Avatar
Slip ford man
I think that the only way of adjustment, was through the variable pushrod lenghts that are available...also used rods should go back in their original hole.
mckeer12
Oct 24, 2016 04:05 PM
coleman12
Oct 21, 2015 03:26 PM
Clem's Cousin
Jul 31, 2015 01:06 PM
kevinclark1990
18
Jul 10, 2015 03:55 PM
97 bonestock
1983 - 2012 Ranger & B-Series
Nov 17, 2009 11:58 AM
