i am thinking about putting a a transmission temp gauge in. i was wondering how hard it is to put in. What lines would go to the trans and if i need to tap into the trans. There are two gauge types, mechanical and electrical and both have different ways of getting installed. Wondering which one would be better
where you gonna put the sending unit in the drain plug, most temp gauges i have seen are for a automatic and just go in the tranny fluid cooler line i dunno if a manual trans even gets hot enough to register on the gauge, anyone else know about this "swap"
