injector leaking
Old Mar 19, 2005 | 05:00 PM
onetuff350's Avatar
onetuff350
injector leaking
just wondering how hard it is to change an injector? about an hour ago i went outside and went to crank my truck and it was bumping like it was running out of fuel and i started smelling deisel so i opened the hood and the first injector towards the front of the motor on the drivers side was bubbling with fuel...should i just try to tighten it or replace it?
Old Mar 19, 2005 | 08:53 PM
Icicle's Avatar
Icicle
perhaps the o-ring went south?
just because its leaking doesnt mean it needs replacement
Old Mar 19, 2005 | 10:00 PM
sourpuss's Avatar
sourpuss
make sure its the injector and not the lines (return) or the injector caps there plastic and they do crack
Old Mar 19, 2005 | 10:41 PM
bigadam's Avatar
bigadam
deffinatly check the injector cup for cracks. Also its a good possibitliy the o ring **** the bed. do not tighten that could lead to more problems. the injector probobly isnt bad and its not hard to pull out , but you have to be care full when u pull it out because fuel will drain into the cyclinder. so if you pull it either drain the rail inthe head or use a turkey baster to suck fuel out of cyclinder!
Old Mar 20, 2005 | 05:21 AM
bilder12's Avatar
bilder12
onetuff,,,there is 2 o rings beneath the plastic caps on top of each injector. They become dried out from the fuel and that causes them to crack and leak. Go to an injection shop or international dealer and get a return line repair kit for your engine and replace the o rings, fuel lines and plastic caps. Do all of them at once, disturbing the system will make the rest leak. You can use stp to make the caps go over the o rings easier and when done, put the rest into the crankcase.
Old Mar 20, 2005 | 11:08 AM
onetuff350's Avatar
onetuff350
it seems to me that the fuel was squirting out at the base of the injector below the plastic peice were it threads in,now if i have to change this is priming the systen required?
Old Mar 20, 2005 | 11:43 AM
onetuff350's Avatar
onetuff350
im not a mechanic but pretty handy if told what to do?
Old Mar 20, 2005 | 11:43 PM
PLC7.3's Avatar
PLC7.3
Won't need to prime it there are still 7 running strong...... You have to check the line to see if the line and the adapter are tight on #1 injector.
Dan92
Feb 22, 2017 03:14 PM
flhorses
May 23, 2010 01:43 PM
coldnorthpole
Mar 3, 2007 07:19 AM
Ford Truck Racer
16
Oct 31, 2006 08:48 AM
