Neutral-safety switch?
Old Mar 17, 2005 | 11:01 PM
JMarkle's Avatar
JMarkle
OK guys, I tried to start my truck this morning, and it wouldn't do a thing with the tranny in park. I could hear the solenoid clicking, but that's it. I shifted to neutral, and it fired right up. Does this sound like a neutral safety switch issue? Can they be adjusted? What is involved?
1978 F150 SC 4x4, 351M, C6
Old Mar 18, 2005 | 09:52 AM
beartracks's Avatar
beartracks
I think if it was the nuetral switch it would not click in the solenoid. Once the solenoid clicks in hot is applied to the starter.
Old Mar 18, 2005 | 10:17 AM
fp_5's Avatar
fp_5
My truck does this all the time. The solenoid does not actually click, but the radio and accessories go out. I have to find the "sweet" spot in park or neutral so that she will crank. I have been meaning to adj. the switch which is located on the steering column near the fire wall but I don't want to lay down on the wet/salty/snow filled dirty floor matts ! If winter ever ends up here I'll clean up the truck and get er done.
Old Mar 18, 2005 | 10:27 AM
buzzbait65's Avatar
buzzbait65
i think the 78 has the switch on the tranny......both of mine did, gone now so i cant check
Old Mar 18, 2005 | 12:07 PM
JMarkle's Avatar
JMarkle
You may be right. . .the solenoid is not actually clicking, but the radio, cb, etc do die when I try to crank it in park.
I looked up the part on AdvanceAuto.com, and it certainly appears to be something that would attach to the steering column. However, looking at it in my Chilton's. . .wow! Very different animal. At least it still cranks in neutral. Thanks for the help guys.
Old Mar 18, 2005 | 01:38 PM
fatherdoug's Avatar
fatherdoug
The neutral safety switch was moved from the column to the transmission starting in 1978. I have a '78 and it is indeed located on the transmission. National Parts Depot sells a replacement, not original Ford, for about $60.
ewales
Aug 18, 2025 08:40 AM
Speedjester
Feb 24, 2015 01:24 PM
danlee
Electrical Systems/Wiring
Sep 18, 2013 01:42 PM
bigcountry150
Mar 11, 2011 12:51 PM
mike9762
Dec 12, 2004 06:14 PM
