Front brake lock-up
Old May 3, 2001 | 11:20 AM
tphelps's Avatar
tphelps
Front brake lock-up
Hi. I just replaced front hubs, rotors, calipers, and pads on my '86 F-150 4x4. After putting everything back together and bleeding the front brakes (master cylinder has separate resevoirs so I assume I don't need to do the back), the front brakes became stuck on after a couple of drives in it (both sides). What kinds of things could be causing this? Could a poor bleed job do this (I'm definitely a beginner)?
Any ideas/suggestions/things to try welcomed.
Thanks,
Tim
Old May 3, 2001 | 02:41 PM
dre's Avatar
dre
Front brake lock-up
Check your push rod(between the master cylinder and vacuum boster).
Sounds like the piston in the master cylinder is not coming all the way back, after releasing the brakes.
Some rods are adjustable.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old May 3, 2001 | 07:27 PM
tphelps's Avatar
tphelps
Front brake lock-up
Thanks! I'll check it out. Think I'm gonna go ahead and replace the master cylinder while I'm at it.
Tim
Old May 3, 2001 | 09:16 PM
billyb's Avatar
billyb
Front brake lock-up
jleo
Apr 4, 2010 01:29 PM
BPuller
Jun 16, 2009 10:42 PM
tcd5834
1997 - 2003 F150
Dec 30, 2006 09:31 PM
BiodieselPanther
1983 - 2012 Ranger & B-Series
Jan 13, 2006 09:12 PM
bartok
May 2, 2004 09:39 PM
