428 timing?
Old Mar 17, 2005 | 10:22 AM
ejfitco's Avatar
ejfitco
Question 428 timing?
I'm running a '68 428 with an RV cam in a '76 High Boy. I'm having trouble with timing. Can some body give me a clue?
It's got a Dura Spark ignition. The engine was rebuilt 30 over and has about 8000 miles on it. When I got it it ran fine but was set a 0-TDC. I didn't think that was right so I advanced it to 8 degrees BTDC then 10 degrees. It seemed to run fine every where I put it. But this can't be right, I'm looking for a home where I can leave it.
Old Mar 17, 2005 | 10:34 AM
Mike G's Avatar
Mike G
Are you running a points distributor? What problems are you having? How do you know it's a timing issue? What changes have you made to the motor lately?
Too many variables you need to tell us still... --Mike
Old Mar 17, 2005 | 11:49 AM
rusty70f100's Avatar
rusty70f100
I generally do this: Advance it 'till it pings, back it off a few degrees, call it good!
Every time you advance it though, you'll want to go drive it for a few days to make sure it's not going to ping. I'd go 2 degrees at a time.
Old Mar 17, 2005 | 11:57 AM
fordeverpower's Avatar
fordeverpower
6 to 10 btdc man!
Old Mar 17, 2005 | 12:19 PM
ejfitco's Avatar
ejfitco
Man... I like simple..cause it can't be complicated for this barn-yard-mechanic.
I do it...run it up till it pings, back it of and that should be somewhere between 6 and 10 BTDC...Thanks fellas.
Old Mar 17, 2005 | 02:05 PM
Todd K's Avatar
Todd K
http://auto.howstuffworks.com/ignition-system.htm this is pretty cool. take a look
OrangeJuice
Jun 8, 2010 01:06 PM
fomoco428
Mar 11, 2010 11:25 PM
buddy76
Oct 21, 2008 06:58 AM
fallingbroken
Jun 25, 2006 04:32 PM
gtex
34
Apr 24, 2003 11:22 AM
