power mirror ?
Old Mar 16, 2005 | 10:36 PM
3pmw825's Avatar
3pmw825
power mirror ?
I'm putting power mirrors in my 92 F-150 NITE. I have bought the mirrors switch and bezle. When I bought the switch it did not come with pigtail. I have the wiring diagram so I know witch wires I need. The only thing I need to know is witch wire goes to each of the 7 prongs on the mirror switch itself. If anyone has a 92-96 F-150-350 and can just pull off their switch plate and tell me the order I would really appriciate it. My e-mail is elvispavesi@yahoo.com Thanx
Old Mar 16, 2005 | 10:50 PM
Icicle's Avatar
Icicle
Welcome to FTE, generally tech questions are not allowed in the user introductions forum, scroll down farther and check out the tech forums, Il report this for you, so It can be moved to where you can get some help
Welcome
Old Mar 16, 2005 | 11:44 PM
Racerguy's Avatar
Racerguy
Moved to proper forum.
Old Mar 17, 2005 | 07:24 AM
crashnburn's Avatar
crashnburn
Power mirror switch connections
bk----[1] [2]-----lg/y
y-----[3] [4]-----not used
p-----[5] [6]-----db
dg----[7] [8]----r
The switch's tab/keyway is above terminal 2
Old Mar 17, 2005 | 12:54 PM
3pmw825's Avatar
3pmw825
I do not have a Terminal #6 on my switch can someone double check theirs?
Old Jul 3, 2005 | 08:12 PM
18fan's Avatar
18fan
3pmw825 I am trying to do the same thing and just wanted to know how your progress was coming on switching to power mirrors.
Old Jul 6, 2005 | 08:23 PM
3pmw825's Avatar
3pmw825
power mirrors
It was actually an easy conversion the only problem I encountered was getting a pigtail to plug into the back of the switch. So I just put a connector on all 6? wires.Also ford charged me 75 for the switch and 25 for the plate. Make sure not to touch any of the terminals together with power goin to the switch or you just wasted 75 bucks! You might want to check and see if the pigtail is inside the door because ford told me if you have power windows they do not sell a seperate harness. Like I mentioned before the NITE option automatically excluded power mirrors from the option list so it was not in my harness but I bought all the right colors and made my own harness
Old Jul 8, 2005 | 05:46 PM
18fan's Avatar
18fan
3pmw825, Thanks for the info. I found the switch and plate at a local salvage yard for $30. I am going to pick it up monday and check if they have the pigtails to plug into the mirrors. Still need to find 2 mirrors, not sure about buying off ebay or checking monday at the salvage yard. Hopefully next weekend I can try and convert mine. Thanks again
Old Jul 8, 2005 | 10:23 PM
3pmw825's Avatar
3pmw825
mirrors
Just to let you know lmc truck is a good source for after market parts for more than half the price of new oem parts. Another problem I encountered when wiring up the doors was on the driver side if you take off the kick panel theres a a solid metal panel behind it that the e-brake assembly bolts to I drilled through it to get into the door but you can also remove the 3 nuts holding the e-brake assembly on and string your wires through there. Let me know if you run into any more problems it's really nice to have power mirrors!
pflueger
Mar 11, 2020 12:31 PM
86step
2009 - 2014 F150
Aug 9, 2013 06:52 PM
tlepisto
Ford Truck Parts for Sale
Dec 2, 2012 05:48 AM
95250mac
Electrical Systems/Wiring
Mar 15, 2008 02:13 PM
Superdutymac
Dec 19, 2004 09:44 PM
