Sponsored by: Real Truck
whining under hood
Old Mar 16, 2005 | 05:01 PM
rmartin11's Avatar
rmartin11
whining under hood
just started tonight....(02 f350 sd).started up truck and heard a whining from under the hood. Not a belt whining but sometind else. Have no idea what it could be. I checked all the fluids (tranny, break, power steering) all full and clean. I washed the truck down the other day and sprayed the sand and salt out from under the hood. I plow with this truck, but have it serviced after every storm. Any ideas??????? It seems to be at the loudest at start up, and diminishes as I accelerate.....
Old Mar 16, 2005 | 05:31 PM
Pocket's Avatar
Pocket
Keep an eye on your alternator.
Old Mar 16, 2005 | 05:34 PM
Monsta's Avatar
Monsta
Sit. Stay.
What kind of engine you got?
All of my Fords have whined but it comes from either the back seat or the passenger seat.
Old Mar 16, 2005 | 05:43 PM
rmartin11's Avatar
rmartin11
its the 5.4,reg cab.
i went out and sprayed some areas with wd40 but it didnt quiet anything. seems to be the loudest around the alternator. just started tonight?
if it was the alternator, is this the warning before it craps out?
Old Mar 16, 2005 | 06:47 PM
Pocket's Avatar
Pocket
Looks like you've got it narrowed down then. Sounds to me like it's going... going... going....
Old Mar 16, 2005 | 07:22 PM
r0n1n's Avatar
r0n1n
i have this problem on my 97 250 right now, i think it's an air leak in your pcv boot....check that and let me know.
-jason
Old Mar 16, 2005 | 07:35 PM
Cowboy Brett's Avatar
Cowboy Brett
As a hip shot, I'd say an idler pulley or alternator. r0n1n might have something with the PCV boot as well. It wouldn't be the first time I saw that happen.
Old Mar 17, 2005 | 12:02 AM
99f350sd's Avatar
99f350sd
Cowboy may have it. Take the belt off and spin the idler and the alt they should make no noise I'm betting on the idler bearing, I had to replace mine last year. Just the bearing. Also for the alt you can get the bearings replaced if thats what it is.
Dick
Old Mar 17, 2005 | 07:02 AM
SLE's Avatar
SLE
You guys are all crazy, I'm pretty sure you just forgot about that Super Charger that you installed last week, lol. Just take the drive belt off of your super charger pully and the noise will stop, probloem solved. Alright more seriously - I agree with the rest check those accesorie components, ie alternator, power steering pump ect.... As far as doing a check use a poor mans stethascope (just a peice of hose) start the truck and route the hose around untill you find the area that it is coming from. If its the Idler pully or the alternator just pop off your belt and give them a spin, you'll probably be able to feel/hear the roughness in the bearings. Good Luck
Old Mar 17, 2005 | 08:49 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
Normally, the whinng under the hood comes from owners who look under there and realize how much stuff was not installed.
Old Mar 17, 2005 | 09:11 AM
jdadamsjr's Avatar
jdadamsjr
or the better half when they see all the money dumped into MUST HAVE upgrades to your truck
keep on moddin
Old Mar 17, 2005 | 12:44 PM
nosdog2's Avatar
nosdog2
Tensioner allso. The bearing in those go bad alot.
ungerp
6.7L Power Stroke Diesel
Mar 13, 2014 07:09 PM
two4two
Jun 7, 2013 03:09 PM
5.4L to Freedom
Dec 16, 2010 05:51 PM
jim6liter
Feb 18, 2008 04:22 PM
Dunnage
1997 - 2003 F150
20
Apr 21, 2005 10:40 PM
