General Automotive Discussion
Hub Puller
Old Mar 16, 2005 | 03:05 PM
JohnAW's Avatar
JohnAW
Hub Puller
Is there any aminal out there call a Hub Puller and if so are they worth renting to take a hub off the rear wheel of a 1992 Buick LeSabre with ABRS sytem.
Old Mar 16, 2005 | 06:54 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
I don't quite understand.
Are you asking about removing the brake drum, or the hub that the studs are mount through?
If it is the drum, just back off the brakes and then remove the drum.
As for the hub, I am not certain, but, you'll probably have to remove the bearing cover, then a cotter pin, then back out the axle nut, washer, bearings and then the hub comes off the axle.
(I believe it should be just like removing the front hub on a rear-wheel drive car.)
Anyway . . . . this seems right.
robertbruce
15
Feb 5, 2013 09:47 AM
broncobran68
19
Jan 24, 2009 08:54 PM
tim684
1978 - 1996 Big Bronco
Jun 16, 2004 08:27 PM
Torque1st
Garage & Workshop
Jun 1, 2002 02:06 PM
jamiew
Apr 30, 2001 09:24 PM
