i,m working on an 86 full size bronco, i need to get the front hubs off to change the u- joints on the axle shafts. I can't get the hub locks out. I took the cap with the six allen screws off and the inner ring and spring. The manual say's the hubs should come right out, or use a puller. I put some tension on them with a puller but they won't come out. I took the snap ring off is there another retainer that i forgot? TIM
look for a snap ring on the edge of the stub shaft, that along with the larger snap ring in the edge of the hub itself will need to be removed. I use a couple of the allen bolts screwed in across from each other to help pull it out, and yes, sometimes they can be a bit stiff. Make sure both the snap rings are out and wiggle the assy a bit, it will come out.
although this is not directly related, i too removed the hub from my 92 Bronco 4x4 in the front because i need to replace the rotors. would anyone give me a clue on how i am suppose to separate the hub from the rotors now? my unit comes attached and the screws that you use to attach the wheel look like they are bolted in some how? i don't want break anything so can anyone help?
Thanks
