Rear diff shudder
Old Mar 15, 2005 | 02:10 PM
WhiteNight's Avatar
WhiteNight
Thumbs up Rear diff shudder
Took the truck in to dealer Saturday for rear shudder while turning at low speeds.They were going to put anti chatter additive in to fix.Went to pick up and they advised about the T.S.B., and are now going to replace clutch.Nice to see that the consumer doesn't allways have to point these things out.Will advise how it works.
Old Mar 16, 2005 | 03:35 AM
greenroses's Avatar
greenroses
WhiteNight,
I'll bet you have the limited slip diff., right?
The shudder you feel at slow speeds is a strong clutch and very effective limited slip diff.
I spoke with my mechanic about the same problem. He said that he'd replace it for me, but the fix is putting in a clutch that turns under a lower torque, thus weakening the effectiveness of the limited slip.
I decided against it.
Old Mar 16, 2005 | 11:13 AM
WhiteNight's Avatar
WhiteNight
Yes.but I am willing to put up with a little more slip.
Old Mar 16, 2005 | 09:36 PM
bdmcdonald's Avatar
bdmcdonald
I had my clutch packs replaced, now its nice and smoooooth!
Old Mar 17, 2005 | 07:18 AM
XXSBlackBirdXX's Avatar
XXSBlackBirdXX
Question ? Locking Front End FX4
Hi folks...
I know we are talking a bit about the rear end shudder... i've got the same.. but as one stated i'll take the shudder for the more firm lock up... but here is my ? it seems my truck has a locking frontend too... on even turf both tires dig and in a tight turn 'dirt' mind you... the truck seems to get into a strong bind/frame twist without slipping the tires... is there a way to learn if the front is in fact a locking front end..??
thanks much
Scott
www.fancyfords.com
Old Mar 17, 2005 | 11:15 AM
WhiteNight's Avatar
WhiteNight
Thats what I'm looking forward to,SMOOTH!!!!
Old Mar 17, 2005 | 11:28 AM
bdmcdonald's Avatar
bdmcdonald
Blackbird, you are probably experiencing what most 4X4's do when in 4 wheel drive. The front wheels are turning at a different speed than the rears, and with the differentals locked through the transfer case via the drive shafts you get torque lockup. If you read the owners manual it will talk about driving on dry surfaces in 4X4. You porbably don't have a locking or LS front diff from the factory. Just my 2 cents worth.
Old Mar 17, 2005 | 11:29 AM
cbreit's Avatar
cbreit
turn steering wheal hard right put a chalk mark on axial flang. mark other side to. DRIVE PULL OVER AND LOOK IF CHALK MARKS MOVED IN 2 WH .IF SO THEN AXIAL ARE TURNING .SHOOD NOT BE.
Old Mar 17, 2005 | 11:37 AM
XXSBlackBirdXX
yes i realize you are right about driving on 'dry surfaces' but when i was working the truck in 4 wheel drive i was in about 1.5 feet of muddy water.... both front wheels where sending rooster tails both in drive and reverse as well as in a turn right or left and even in the wet conditions as you say you can feel the torque begin to stiffen up.. i learned a very hard lesson some years ago with a front dana 30 on a bronco that was an open differential and having it locked up on asphalt... split the carier among other items... ouch.... let me know your thoughts on this if you don't mind.. thanks much...
Scott
Old Mar 17, 2005 | 11:38 AM
XXSBlackBirdXX
should i run the truck in 4 wheel drive while the shafts are chalked... thanks again.. Scott
Old Mar 27, 2005 | 12:35 AM
WhiteNight's Avatar
WhiteNight
Thumbs up
Had rear diff clutch replaced today.While driving truck home kept expecting the shudder to reappear, but it's gone.Totally different truck.
SuperDutyScaler
Aug 20, 2013 09:48 AM
geodody
19
Jan 28, 2013 05:03 PM
Mo Power
2009 - 2014 F150
Aug 3, 2011 12:16 AM
Cell's
Jun 2, 2011 12:04 PM
mwmod97
2004 - 2008 F150
May 6, 2005 04:16 PM
