vibration or shudder while towing
Old May 6, 2005 | 09:52 AM
mwmod97's Avatar
mwmod97
I haven't really found any info out there about the vibration or shuddering issue while towing, so thought I would throw this out there.
I just got an 05 Supercab fx4 4x4, with 5.4, 3.55 gears, and General p255/70/17 tires. Rides nice and smooth with no vibrations or shuddering, until I tow a 18 foot open trailer with a 2600 lb race car on it, then it gets a vibration. Don't matter what speed I am going, it is there, it just seems to get worse the faster the speed.
Just curious if anyone else out there has this problem only while towing. thanks
Old May 6, 2005 | 12:13 PM
92merc's Avatar
92merc
I'd be guessing one of two things. First one may be a tire. More load force throws it off where less load it isn't as noticable.
The other possibility is your driveshaft/pinion angle. When putting a load on the back, you're changing the pinion angle just enough to have it vibrate.
Just a layman's opinion from a computer guy.
Old May 6, 2005 | 02:21 PM
bimmerbill's Avatar
bimmerbill
I have the same thing. But I have a 04 Lariat SCrew with 3.73s. I took my 19' boat (1500 lb boat, 500 motor, 500 trailer) for a test tow last weekend just to see how the new truck tows compared to my old 97 lariat 4.6L.
Well, I had this weird shudder, sort of rythmic, faded in and out. Was very strange. My hitch seemed very loose in the receiver, I could wiggle it back and forth quite a bit. I just found out there is another hole in the receiver, which should position the hitch deeper into the receiver.
I hope to try that out and take it for a test tow this weekend.
The hitch is much tighter in the 97 Lariat's receiver.
Anyone know how much play (wiggle room?) there should be?
Maybe you have a similar issue?
Old May 6, 2005 | 04:16 PM
ctfordguy's Avatar
ctfordguy
I have an 04 HD SCAB. First time I towed a serious load I had this unbearable shake at 50-55 mph. I rented a U-Haul car flat bed for my wifes Jeep Liberty. The shake was there with the trailer empty or loaded. The total weight was about 5800 lbs. I had just installed BFG Mud Terrians on WELD wheels and did not have any problems prior or since about 1 year.
2 months ago I purchased an 05 Mustang GT from a dealer 200 miles away. Rather than drive it home I rented the same type trailer for the Mustang. I did not pull the trailer empty, but there was no shake like before. However it was a different trailer and I had installed the OEM rubber and wheels for the winter, MUD terrians dont like snow. I would guess that the tires are what caused the shake. Ford recognizes that there is a problem with the tires on the 04 as they extended the warranty, I would have the tires checked by the dealer.
majestek12
Sep 16, 2015 02:06 PM
sonsila
13
Mar 10, 2014 02:48 PM
Tugly
23
Dec 29, 2012 06:06 AM
Akumida
Apr 22, 2011 09:34 PM
mwelch1169
6.4L Power Stroke Diesel
Aug 22, 2007 03:28 PM
