Explorer ABS light, RABS Code 9 HELP
Old Mar 14, 2005 | 09:28 PM
Dr_Doug's Avatar
Dr_Doug
1991 Explorer 4WD
ABS light lit. Grounded wire retreived code 9 (open speed sensor) Ohmed sensor - OK. Replaced anyway. 130,000 miles.
Light still on. Is there a way to check the resistance of the speed sensor upstream to verify the integrity of the wiring harness / connector?
HELP NEEDED.
Thanks.
Old Mar 15, 2005 | 04:30 AM
sjwoody's Avatar
sjwoody
Yes there is a way...
Remove the connector from the RABS module. (I'm not sure where it is, but I think it's between the steering column and the radio area under the dash). Pins 3 and 10 are the same wires going to the sensor. If you have greater than 2500 ohms resistance, your sensor or wiring is bad. If you have the fault 9, and the resistance is less than 2500 ohms, then the module is bad.
If there is a wiring fault, I would suggest disconnecting the sensor plug and jumpering the two pins. Then read your meter at pins 3 and 10 at the module end to make sure you have little or no resistance. You might want to check each pin to ground (with both ends of the harness disconnected) to make sure you don't have a short to ground. It would be good practice to disconnect the battery before doing any of this.
Good luck.
Old Mar 16, 2005 | 09:32 PM
Dr_Doug's Avatar
Dr_Doug
Fixed, thanks
I traced the problem to a varmint eaten wire. This is the third time that this has happened in 6 years. Twice to my fuel supply line to tank and three times to the ABS harness. (There is a small shelf over the rear axle that a squirrel or something sits on and leans down and chews away.) This time, the chew mark was so small that I didn't even visually detect it.
I am getting tired of the repairs and unfortunately may resort to baiting the shelf with poison. Beats standing outside on a 24/7 watch.
Thanks,
Old Mar 17, 2005 | 03:51 AM
sjwoody's Avatar
sjwoody
Wow, I'd never thought of that possibility...Glad you got it fixed.
1995droptopz
Jul 15, 2011 09:48 AM
hammerhead90
Dec 27, 2010 08:10 AM
Toy4Dad
Apr 8, 2010 02:20 PM
ynot2244
Feb 17, 2010 06:41 AM
uncleAl
Sep 8, 2007 05:47 PM
